Ellis, I was looking through Handcrafted Shelves and Cabinets and saw a cabinet you had designed for a house in Pennsylvania. Reading further, I saw you had at the time been a professional for about 10 years. And you got started on your career by building yourself a table, which an interior designer liked and got you to make one for a customer.
So, would you have a picture of your first table? I'm just curious.
The book was published in 1984 and it's neat to read about all the craftsmen of that time period.
Wow, I didn't think anyone remembered that book. I'm pretty sure the table I was referring to was an Indian rosewood dining table I made for my growing family around 1975 (back when you could still get 12"-wide stock for ten bucks a foot). As luck would have it, I still have that table and we just finished a lovely meal there tonight. Here are a couple awful snapshots of it. It's long overdue for refinishing since my grandkids messed it up a while back, so pardon the blotchy look.
The tabletop is made from three boards of rosewood and is 3' x 5', with curved sides and ends. The understructure is kind of interesting, consisting of two curved longitudinal rails glued to the underside of the table, and two cross rails through-tenoned through the long rails to allow for expansion, of which rosewood has precious little. The legs are knockdown, consisting of two 2"-thick white ash "U"-shaped assemblies that overlap in an "X" pattern in the center at floor level. The tips of the legs are bolted into the long rails at the junctions with the side rails, making for quite a stable assembly. I also have a shorter mahogany base that I can substitute for the dining table legs if/when we want to use the top as a big coffee table.
Thanks for the memories. Hard to believe it's been 40 years since I made this piece.
That was the prototype for a set of ten chairs I was commissioned to make for a client near Philadelphia back in '78. The motivation for the design was that the customer had a shag rug (popular in those days) in the dining room and conventional chairs would have been impossible to move in and out. So, I designed a sled base that glides smoothly on the rug.
The key to the design is the continuous back "rail" that returns to the front forming the front "legs" of the chair. The back splat is rosewood, suspended between two other laminations that intersect the back at the top. The seat is a simple upholstered shell cushion that sits on two dovetailed stretchers. There are quite a few unconventional techniques in these chairs, including wedges glued in between the laminations at the ends to flare them out, hot-pipe bending the tighter curves before forming them up, and twin tenons paired into single mortises at the back leg joints.
I made the first set of ten out of ash with solid Thai rosewood splats.
A few years later I made another set of six with Brazilian tulipwood veneers on the splats for a customer in San Diego. The table that I designed to go with them is based on the rosewood table shape and leg design of my own rosewood table that I posted above, except that it is an extension table, with the ends sliding open on siliconized wooden wear strips made for the conveyor belt industry.
The flitch of tulipwood veneer that I used for the top had a nice gentle curve to the grain pattern, which mimicked the end curves of the table design. If I had straight-line ripped them, it would have produced a disjointed pattern when slip-matched. So, I made a pair of curved routing forms that I clamped the veneers in and flush trimmed them to a curved shape. The trick there was to have the inside curve match the outside curve exactly so that they'd tape up seamlessly. It worked like a charm. The two curved halves are then bookmatched and laid up on veneer ply.
At between 60 and 100 hours per chair, these things were grueling to make, and I was fortunate enough to have well-heeled clients who could afford them. It must have been a leap of faith. After this second edition, I burned most of the jigs I used to make them. I did keep the main form though; it's out in my shed somewhere. It took me almost a month to make, since the curvature had to be a shape that these twisting laminations would actually conform to, and that took a lot of trial and error. The chair was included in Taunton's Design Book Two, published in 1979.
They remind me of some chairs I did back around then. We must have had shared influences.
After this length of time, I'd be interested to know how you would change the design if someone could talk you into doing a revised version of these projects?
I would spend the additional time and effort to put a more ergonomic curvature into the back assembly, not that these aren't comfortable (to me at least) as they are. But that would require either bandsawing the splats out of heavier timber ($$$) or forming them, and it would add to, not subtract from, the time spent. I'd also play with the curves in the base a bit, but, other than that, I was pretty well satisfied with the design. With four custom laminations per chair, though, and all those wedges and hand-cut tenons and jigs, I don't see a good way to cut the time factor.
Each piece, chairs and tables, is "signed" with my signature, a little inlaid, scrimshawed ivory rosebud, which I adopted back in 1970 and have used ever since. In Sufi mysticism, the white rose is a symbol of the quest for perfection. A vanity to be sure, but there it is. More recently, I had a branding iron of the rosebud made. It's a lot quicker.
The chairs are fascinating and I would have enjoyed seeing the jigs and procedures for making them. A nice touch to do curved seams on the veneered top. It would have been fun to have hung out in your shop back then.
Very inspirational. I love the idea of a design inspired by shag carpet, though it works just as well on wall to wall, which I guess is almost equally obscure. My little shaker trestle coffee table is a lot of fun that way, one can just slide it anywhere on the carpet with ease.
