Sandblasting-Would this work?
Thomas E Norton
Picked up a pressurized sandblaster at HF to refinish a few bike frames. I would vlike to make up a sandblasting cabinet out of plywood. Had a thought of installing a pleated air filter so that the Air going vinto the cabinet could exhaust.
Thoughts???
Re: Sandblasting-Would this work?
Clint Searl
Clint Searl
Absent any real constraints, a cabinet is superfluous. I have both a pressure tank and a simple syphon feed, and the syphon is more convenient and just as effective. I use playground sand sifted through window screen. Make sure your compressor can deliver sustained 100+PSI.
Thomas E Norton
The reason for the cabinet is with the weather getting worse I would be able to work indoors.
Virgil Johnson
I would not recommend an indoor sandblaster in a small shop or house. You will have a lot of fine abrasive dust escape despite your best efforts to contain it. This is from my experience with commercial cabinet type blasters in a machine shop. Pressurized blast media is hard to contain.
Thomas E Norton
What if I incorporated a vac?
Mark Hennebury
Hi, I have a homemade sandblasting cabinet, made from MDF. I use it with a 5hp dust collector. This way you always have a negative pressure in the cabinet even when you are blasting . this helps keep the dust contained. I also have it inside a plastic covered spray booth room in the shop. Its still a dirty tiring job. Sand gets everywhere just from recycling the sand, sifting and refilling the pressure pot.
That said sand blasting does a great job, but as already stated you need a strong sustained airflow from your compressor. I have a 4 cyclinder 7.5hp Devilbiss and it takes all it can give.
I built my cabinet with a double back with a 1" space between the backs. The inside back acts a baffle and has an opening at the bottom, the dust collector opening is at the top of the outside back.
Dick Coers
I used a commercial cabinet for years in the model shop. No dust problems, it had a great vacuum system to limit any dust getting into the shop. You definitely need something to clean the air inside the cabinet, or you won't see your work after a very short time. Tons of ideas on the internet on how to filter the air in a HF cabinet. Just adding a shop vac will likely end with short life to the vac. Use a cyclone or similar to take the grit out of the air before the small vac filter.
Virgil Johnson
The blasters at the shop had a vac/recycling system. It may have been the fact there were many different operators.Some would maintain the system better than others. The thing was handy but messy.
Ralph Lipeles
My cabinet and setup sounds like it is very similar to yours and it does a great job. I have a small piece of window screen on the inside of the cabinet by the shop vac connection to reduce the amount of sand that escapes. I have a hinged top with 2, 18" square pieces of glass to provide good visibility. There are 2 pieces of window screen inside the cabinet that cover the glass windows to reduce the deterioration of the glass from the sand. The strips that retain the glass are screwed in to make replacement of the glass easier. There is an easily removable screen covered shelf inside to support the pieces being blasted and a hopper shaped bottom to recirculate the sand efficiently.
Clint Searl
Side note:
Clint Searl
Protect goggles and hood/cabinet window from bounce-back with SaranWrap.
