Veritas - Innovation in Tools
Pricing a job
Pricing a job
Pricing a job
Rick
Hi. I have been asked to price the refinishing of a large, cherry dining room table. Not sure where to go with this and I don't know how long it will take me. Have you done a similar job and what did you charge for the stripping, staining and application of the top coat?
Thanks,
Rick
Re: Pricing a job
Hard to say...
John in NM
Has a lot to do with the existing finish, how you plan to strip it, whether the table is solid or veneered, and your level of experience with finishing.
Usually if I don't know how to bid a job, I either pass on it or make a best guess and chalk it up to experience if I end up under bidding. The only way to learn how long something will take you is to do it several times.
Incidentally, I find refinishing to be such a chore that I rarely will do it for pay.
Re: Pricing a job
Re: Pricing a job
Bill Turpin in WNC mountains
From my experience remodeling restaurant kitchens: double the materials and quadruple the time. You might make a little $.
Re: Pricing a job
Clint Searl
Re: Pricing a job
Clint Searl
T&M with Time at $45/hour , but no less than $1000.
Re: Pricing a job
refinishing is fraught with time traps
Dick Coers
Too difficult to give you advise. No idea of what the clear finish is, no idea if a toner was used to build an even color, no idea if they used a lot of wax or any product that will result in silicone contamination, or even if there are complex moldings that will take more time to clean. Guess how much time it will take, and at least double it. I have to be desperate for cash to do that kind of work, and it almost has to be a relative to justify the aggravation!
Re: Pricing a job
Re: Pricing a job
David Yoho
I've done quite a bit of refinishing work for clients over the years. I actually prefer it to building new for customers because there's no time invested in plans and no materials to purchase and pick up. The biggest part is your time and cost of materials to strip and refinish.
As Dick and John pointed out, it's hard to give an exact answer without seeing the table. Any number of things can affect the difficulty you may encounter and, thus, the time it takes. If you aren't normally equipped for this work, there will be a greater expense to gather up what you'll need too.
I've done several dining tables. The best case would be if the table is solid wood without veneer. Too many times these things are veneered and has chipped or missing pieces. It takes a great knowledge of repair or replacement to do this part right. Also if there is intricate carving on the legs and/or skirt, you'll need to deal with that correctly. Then there is the matter of leaves that will figure into how much work it takes.
The removal of the old finish is easy enough if using the correct stripper. It's the sanding and surface prep and applying a new finish that eats up a lot of time and effort.
All in all, if you are up for the job and have enough finishing skill to get it done right but still don't know what to charge, I would say to decide on a price that you would be comfortable with and go with it. Don't be shy of giving one that might seem high to you. They will either say yes or walk away. However, you will be the one handling the toxic stripper and removing the old finish by hand versus the dunk-tank type shops. You will be the one that applies the fresh new finish. If everyone was doing this they probably would have asked someone else. However, there are few individuals out there that do refinishing for the reasons expressed by others who responded already. I think this allows for a price quote that might seem high to some but who else will they go to?
Re: Pricing a job
Re: Pricing a job
Brian Roberts
Why do they feel the piece needs re-finishing?
Do they want a different color?
A total strip will likely remove any patina that may have developed...are they aware of the downsides?
Is it possible that just the top needs refreshing?
As others have stated...more info needed.
Re: Pricing a job
Re: Pricing a job
Rick Van Schoick
Thanks for everyone's feedback. I have refinished furniture before and have worked with cherry before. This is for a family friend which is why she asked me, and I also really need the cash. This is a solid table top and the finish has been marred from years of use. A refresh? Perhaps. I didn't really consider that and wouldn't know what to do. I've always stripped and refinished. There are no moldings and no veneer to worry about. I will tell you that the craftsman who put this together originally probably could have chosen his wood more carefully because there are strips of sapwood that kind of mar the beauty. Perhaps a toner on those to blend in the color? Sounding more and more like a bigger job. She only wants the top refinished; no legs though one swinging leg may need repair. I can do that as well. As to the top, I've never refinished such a large surface and I don't have spray equipment. I'll have to do that by hand.
If I was to consider renewing instead of refinishing, what are the steps involved there?
Thanks,
Rick
Re: Pricing a job
Again...depends...
Brian Roberts
on several things.
Damage to just the finish....or into the wood?
What is the original finish?
Shellac or a nitro lacquer would be the simplest.......additional coats amalgamate with original finish...with all polishes or waxes, etc. removed first of course.
Be careful about using any toners to blend sap wood. What looks like a perfect match in your shop may look quite different in sunlight or in the owners area!
Re: Pricing a job
Re: Pricing a job
David Yoho
Again, not seeing it for myself, it's hard to give an accurate way to proceed. However, there are a couple of issues to think about.
Is the cherry dyed or stained? Is only the finish marred or does it go deeper to the wood? These lead to - will the refinished top match the base and legs when completed, will the exposed sap wood be a problem, and if only the finish is marred how to revitalize the finish without stripping.
And then there's this - if the cherry has been stained or dyed can you accurately match the color of the base and legs? Cherry is particularly difficult in this scenario due to how quickly it darkens. Do a great color match and it will only last a short time until the cherry darkens under the finish and things change.
I've had a number of occasions in the past when I advised the customer their piece didn't require stripping and refinishing because the finish was in great shape. It just needed a good cleaning and polishing. My approach was they could dig deep into their pocket if they really wanted me to totally refinish but it would save them quite a bit if I just restored to original finish. Every time they decided not to refinish they were blown away at the difference after I had done my work.
Re: Pricing a job
Re: Pricing a job
Rick
David, what were the steps you went through to restore the finish without refinishing it? Also I didn't see any problems with the wood. Just the finish. But the biggest mar seems to be something that is on top of the finish. Doesn't come off with soap and water. It doesn't look like the table is stained. Couldn't tell you what the original finish is. It's old. I doubt it would be shellac since alcohol use on the table wouldn't be a good pairing, right?
You can see one of my restorations here: http://www.rickswoodshopcreations.com/Projects/Completed/Antique_Rocker/Antique_Rocker.htm
as well as here: http://www.rickswoodshopcreations.com/projects/Completed/Antique_Dresser/antique_dresser.htm
I just dabble :-)
Rick
Re: Pricing a job
Re: Pricing a job
Bruce, a MN Galoot
Pretty darn good dabbling!
Re: Pricing a job
Re: Pricing a job
David Yoho
Dabble my big ol' butt!!! Nice work on the rocker. One of the reasons that I like, unlike others, refinishing and restoration is because of how much I've learned about construction methods and joinery used in old furniture. It's also strengthened my finishing skills. I'd say you're up for whatever you run into with that table.
The process I use to restore an old finish is one I learned from a professional restorer of historic furniture in Charlottesville, VA many years ago. My guess about the finish on that table if it's got any age to it would probably be a varnish. I'd probably rule out polyurethane but you never know. If you find it is "scuffed" in areas you could probably clear that up with finer grits of paper and something like water for a lubricant. Just need to be careful.
As long as the topcoat is in good shape, what I do is start with cleaning it. I use a specific product and would not substitute it for reasons I'll leave out for brevity. I use Permatex DL Blue Label waterless hand cleaner and apply it with a white Scotch Brite pad. The white pads have no "grit" like the other colored ones, so it doesn't scratch but is great at scrubbing. You can find the hand cleaner in places like Auto Zone stores and Sherwin Williams stores.
The solvent in the Permatex will not hurt the finish but is good at loosening dirt. I wipe the surface down afterward with a sponge, wringing it often until no more dirty water squeezes out. Let the surface dry and then it's time to polish. I like using Briwax for this part because the solvent in it is great at removing any dirt or film that the cleaning missed. I also like it over Johnson's because it buffs out to a higher shine. After buffing the waxed surface your finish should look like a new penny.
Re: Pricing a job
Re: Pricing a job
del schisler
i wouldn't do that job, if the unit is not solid cherry , and has a spray finish to look like cherry , it may be some other wood and you wouldn't be able to make it cherry looking like it was , make sure it is solid cherry first, i used to do refinishing and it is not easy to do, if you don't have spraying equip. ect than i would pass on this
Re: Pricing a job
Re: Pricing a job
Rick Van Schoick
Thanks David. Today I'll take a closer look at the table and check out the integrity of the finish. I would prefer to go this route if I can. Thanks for your help.
Rick
Re: Pricing a job
Re: Pricing a job
Rick Van Schoick
David, do I need a power buffer or can I do it by hand?
Rick
Re: Pricing a job
Re: Pricing a job
David Yoho
Rick, I use a power buffer. I find Briwax a little harder to buff out by hand, especially if it goes on too thick in places.
Re: Pricing a job
Re: Pricing a job
Rick Van Schoick
David, took another look at the table today and the finish is in really bad shape. I think I'm going to go ahead and refinish it and let the natural color of the wood stand out. It doesn't seem to have been stained. What type of spray eqpt do you use?
Thanks,
Re: Pricing a job
Re: Pricing a job
David Yoho
Rick, I have a Fuji Q3 turbine but I don't use it often. The vast majority of my finishing work is done by hand. More times than not I use Arm R Seal or Waterlox varnishes that I wipe on. I have my technique down so well now that I'm often asked if I sprayed it and with what.
As you probably know, the really important steps to refinishing begin after the old finish is removed. Preparing the wood surface for the new finish and applying it are where you win or lose. The last refinishing job I did was the top of a Baby Grand Piano. I wiped Waterlox onto the curly walnut veneered surface and it came out looking like a sprayed piano finish.
