REAL MILK PAINT
demilune crotch stained
Before assembling the skirt to legs I stained the crotch veneer on the table skirt. The stain is 15 wt.% burnt umber japan color, 15% linseed oil and the remainder General Finishes "conditioner" (unnpigmented stain) which is what I was told GF uses to prepare their oil stains. I like the result of this recipe. It provides lasting color which isn't too dark.
Crotches can go too dark when they are stained and obliterate the figure.
Before stain I sealed with a wash coat of 5 wt.% shellac in alcohol to retard the uptake of the pigment.
Re: demilune crotch stained
Re: demilune crotch stained - Question
Bob Entwisle in NJ
Looking good Bill, and thank you for sharing this build.
I know that you are not a fan of the traditional 'Lb cut' description of shellac, and I just wanted to clarify in my mind:
"Before stain I sealed with a wash coat of 5 wt.% shellac in alcohol to retard the uptake of the pigment."
Do I understand that correctly to mean 5% by weight shellac flakes and 95% by weight Alcohol?
Thanks
bob in NJ
Good recipe
Do you sand the wash coat before you stain, so the shellac stays mainly in the pores?
Re: Good recipe
In general yes but when "washing" a crotch it is like adding liquid to a sponge. In seconds its gone into the wood and the surface looks dry. So in fact for this case I didn't scuff sand because there was nothing to sand.
The problem of course is that the same thing happens to stain if the grain is motsomewhat sealed. A crotch can go nearly black. How much to seal comes from experimentation.
