Flooring question
Flooring question
Flooring question
mdclor
Good morning to everyone,
I am installing natural pre-finished 3/4" maple flooring. What product is best for filling the face nail holes? DAP, Minwax, etc? Oil or water base?
TIA
Re: Flooring question
Ralph Lipeles
I thought that when installing tongue and groove flooring, the nails are put in at an angle through the tongue. Doing it that way there are not any visible nail holes.
I would .....
Brian Roberts
use a blind nailing procedure.
Either a commercially available unit like this:
http://www.leevalley.com/us/wood/page.aspx?c=&cat=1,41182&p=32683
Actually I used one of my carving gouges to lift a chip...leave it connected.....and experiment first on a scrap to get the hang of depth and angle of the tool.
Works quite well.
Not necessarily
David Yoho
You can't get the nailer oriented close to the wall so that strip has to be face nailed.
mdclor
Ralph, David is correct that you can't use a flooring nailer close to walls, etc. Brian, the LV tool is no longer available. I could try the method, but I think it will be more time consuming and, personally, I find it to be intimidating/scary. :)
Bruce, a MN Galoot
I just used my brad nailer and 2" brads. It leaves a very small hole and you can get very close to the baseboard.
Mark Nowicki
Nothing.
The nail holes are small enough not to be visible, in many cases they end up being hidden under furniture or casing and shoe molding.
Some of the rows that the nailer can't reach can be hand nailed through the tongue. Drill an angled pilot hole and sink the heads with a nail set.
George Koch
All I've ever used was colored putty of the correct shade, bought at the local paint or hardware store.
It doesn't matter
As others have said the holes are off on the edge of the floor and will be unnoticed. I have used whatever filler I could handily find.
I don't recommend the brad nailer. I don' even like the ideal of finishing nails because they don't hold well. I have used the nails that are used in the flooring nailer.
These nails need to have good holding power. In my youth one could find flooring nails, a beefy finishing nail with a screw shank.
mdclor
George, do you remember any particular brands that you were or were not happy with the results?
mdclor
Mark, the last 2-3 rows are problematic because I am using 2.25" strips and even with drilling, I don't have enough room to swing a hammer.
Re: It doesn't matter
mdclor
Bill, I haven't seen those nails in a long time either, but even if I had them, I would want to sink them and fill the holes.
Mark Nowicki
Use trim screws.
I like the trim screws.
For filler, I would use something water based, at least not oil based. In the past I used oil based putty under latex paint. The oil bled through. Probably woudl not happen with pre-finished flooring, but why take a chance?
mdclor
Mark, am I missing something? Wouldn't trim screws need to be sunk and filled in above them?
mdclor
Barry, thank you for answering one of my questions. Water base it is. :)
George Koch
The brand I've been using is "Color Putty" from the Color Putty Co. made in Monroe WI. It is oil based but it doesn't matter because it's used after the sealer is applied and you said it was prefinished flooring. George
Mark Nowicki
In my experience, I have only had to face nail the last strip.
Once the nailer runs out of room, I drill pilot holes and hand nail through the tongue until the last strip. You really don't need room for a full hammer swing, but you said you don't have, or feel you don't have room for that.
You need less room for a screwdriver, power or hand, hence my trim screw suggestion.
On a 2 1/2" strip floor I would just glue the last strip and not bother nailing, if appearance is a concern.
Another option is to glue up the last couple of strips, and just face nail through the last strip.
I have done that on a few occasions.
