cleaning question
Ed O'Neill
Hi , Living in SC has continually caused the top of my unisaw to rust. Any suggestions on how to restore to its former beauty ? Thanks Ed
cleaning question
Ed O'Neill
Re: cleaning question
terry quiram
Palm sander to remove rust. DNA to clean surface. Wax then put a piece of plywood on top of your saw when finished for the day.
John in NM
I would try scotchbrite for rust removal, but living where I do I have vastly less experience with this. Terry's suggestions for prevention sound like reasonable steps to try.
Keep it waxed to minimize the problem. Short of grinding it pas the oxidized layer, no, to answer your question.
David Yoho
Doubt you'll ever get it back to looking the way it did new. I don't worry about that. For me, a clean and accurate saw is important. All I use to remove any surface rust is WD-40 with a grey Scotch Brite pad rubbing with the grain. Wipe it down and apply a coat of Johnson's paste wax and buff. Keeping your cast iron surfaces on saws, planer beds, bandsaws, or jointers not only protects from moisture but makes the wood glide on the surface.
Don't think I'd take a power sander to it. Surface oxidation can be easily removed with a bit of wool (steel or synthetic), and sanding the top to get to deep pits will wreck the accuracy of the top surface.
I suggest as follows:
1. Use wool and a light oil lubricant (wd 40 or mineral spirits) to remove the light oxidation. Wipe clean and dry with paper towels that are disposed of properly.
2. Apply a phosphoric acid preparation (Naval Jelly, Must-For-Rust, etc.) and rub it into the metal's surface very well, especially in any area with deeper rust pits. This changes iron oxide (rust) to Iron phosphate (a crystal) that retards further rusting. Rub the surface again with wool and remove any loose residue. You may see darker points or "shadows" in the surface where the crystals have formed.
3. While I prefer Johnson's paste wax, I know others who have moisture issues in their shops and they prefer the rather expensive Bo-shield preparation to prevent rust on their cast iron surfaces.
Now, if you really want to go whole hog you can
a. remove your table and have the pieces reground (Blanchard or otherwise) or
b. buy a new top set from Delta
It ain't that hard, guys....
Kent B
Simple.
To remove: Non-woven Scotch pads. Elbow grease, or stick a chunk on your hook-and-loop ROS. The worse your rustiness condition, the "grittier" you get. Maroon and grey is where I land. I use MS as a lubricant - get it all cleaned off when done, and wipe down with DNA to ensure nothing left.
To prevent: Boeshield T-9. Boe as in Boeing invented the stuff - aircraft related. You gotta spend a few bucks to get it, but apply it as they say, and you are gold.
I also put Johnson's paste wax on it - not as a preservative, but as a "slipper-i-ness enhancer". Makes it much easier to move the wood across TS or jointer tables.
Another option...
John in NM
Steel wool the rust just enough to remove the dusty stuff, then oil or wax the remaining rust. Gives you a hard brown finish like that used on some old muskets (I am kidding of course
he said.....
...."restore to its former beauty". That ain't gonna happen short of grinding it. But what you suggest will get it more than good enough to use.
wha???.
Kent B
where did I say that?
Hmmmm......... never my goal.
Restore to functional is plenty good enough for me.
He meant...
John in NM
The OP said that.
I go for functional too, with aesthetics present but in the back seat
Re: He meant...
Kent B
Story of my life.......
Shot at and missed
Sh** at and hit.
It's happened to us all...
John in NM
No worries
Re: It ain't that hard, guys....
For porous cast iron, the European toolmaker Robland recommends rubbing talcum powder into the surface with a chalkboard eraser. They claim it fills the pores and prevents rust.
I have been doing this on my Robland/Leguna sliding table on my PM66 and so far it works well. Makes things slide nicely too.
The trick was finding pure talc without additives and that didn't smell like a baby's changing table. Amazon carries it for billiards persons.
Big Bad John?
You a pool-shootin' boy?
Not me.
I am unquestionably an expert pool shootn' watcher.
When I play I am highly proficient in the refined art of the creative scratch.
BOESHIELD T-9 & Rust Free
del schisler
sears has is it , i live in florida 10 miles from ocean and i have no rust on all my mach. i have at least 6 beds and no rust, that is just me , but this BOESHIELD T-9 & Rust Free have used this for yrs now
I always liked....
John in NM
The scratch where the cue ball leaves the table
If you're going to scratch, might as well REALLY scratch
William Duffield
Only problem with that technique (which I also use, by the way) is that the MS eats the ROS pad.
Re: cleaning question *LINK*
Jim Dillon
Ed, I've had luck with these Abraser blocks from Klingspor. IIRC, I spray a little WD-40 or Boeshield T-9 on them and have at it. Then wipe thoroughly, allow to dry and apply a coat of Renaissance wax. Seems to work OK. Jim
Klingspor Abraser Blocks
fredhargis
I recently learned of these non-woven belts for belt sanders and bought a few. They really work well, and are (or can be) made to fit any size sander.
Sparky Abrasives
Sand blast and wax
