but I did it anyway - actually in the open shed back of my shop. When I went back, I have a piece with a white finish. I know it has to do with moisture trapped in the finish but I've forgotten how to deal with it. Bring it in to let it dry completely and recoat or sand it off? Fortunately tomorrow is supposed to be sunny again.
Re: I know better than to spray Laquer in the rain
Dick Coers
You might be able to spray some thinner over it tomorrow and take out the blush. You sure don't have to sand it, lacquer thinner will wash off the finish tomorrow quite easily. If you have to spray in high humidity, get a slow thinner from an auto finish supply house so it will flash off more slowly. Spraying in a shed isn't going to work very often with high humidity, no matter what the thinner.
del schisler
i do it all the time, here in florida 10 miles from ocean the humidity get high in the morning , but i spray the seal coat on, it turn's white , but i let it dry a couple hours and in the afternoon when humidity is low in the 60's i sand the sealear to get the fuzz off and than spray the over coat and it comes out fine , i been doing this for yrs and it works, you don't have to sand it all off, it will blend in fine , also i spray no more than 3 coats on. good luck
Alan Hollar
Mohawk makes an aerosol blush eliminator,mostly Glycol Ether EB aqs I recall, called No Blush Plus. Spray sparingly, the retarding effect of the product is profound.
Evaporation is a cooling process. The solvent began to evaporate and the temperature of the surface became lower than the dew point of the air in the neighborhood. Water condensed on the surface. This water precipitated the finish out of solution as particles rather than a film. Particles scatter light and appear white.
To fix spray with a retarding thinner. It will have a higher boiling solvent formulation that will evaporate more slowly and hence cool less. Also because it is slower to evaporate it will have a greater time to do what is needed. This solvent coating will redissolve the lacquer particles and redeposit the lacquer as a film. All will be fine.
