Router template help
Dan
I'm building a small box for a co-worker to place her cat's ashes in. Along with the ashes, she received a casting of one of the cat's footprints. The idea is to inlay the casting in the top. I've got a 1/4" straight bit that I'll use with a 3/8" guide bushing to rout the "hole" for the casting.
My question is, how do I get an accurate and properly sized template? So far, I've scanned the casting and printed it, as well as measured the casting and printed the scans so they should be about 1/16" larger to accommodate the bushing. The problem is the edges of the casting are sort of rounded from top to bottom, so the prints aren't sharp at the edges. I haven't done anything with these printouts yet.
I know trial and error is a viable option, but my t & e usually goes "too small, too small, too big" so I'm hoping some folks with more experience can provide some insight. I'll probably be using hardboard for the template. Thanks. DB
Re: Router template help
Dick Coers
You could rout it a bit oversized, then bed it I black tinted epoxy. Other than that, it's rout undersized, then sneak up on the fit with carving gouges.
don stephan
Many router bases are sized to accept Porter Cable template guides. From the outside diameters of the template guide and router bit one can calculate the needed diameter of a whole in the template to result in a perfectly round recess of a particular diameter.
Bob Lang
Assuming that you want a paw-shaped hole. Risky as it sounds, what do you need the template for? If you can make the template, why wouldn't you be able to make the recess in the top itself? Chances are good that your bit/template diameters won't reach everywhere you need to go and you'll be doing hand work anyway. The offset from bit to guide bushing is compounding your problem.
If it were me, I would lay the casting on the top and trace around it with a sharp pencil or an X-acto knife. I would use a trim router in a plunge base with an upcut spiral bit. They key is to be able to see the lines, set the depth of the router, start the cut in the middle and nibble your way as close as you dare to the pencil lines.
You likely will have to ruin a couple of practice pieces, but that's the way it goes sometimes.
You could find someone who could turn the outline of the casting into a vector path and cut the recess with a CNC router. That's probably a bit much for something this small.
Bob Lang
Dan
Thanks for the input. DB
Good advice, Bob
I used to do a lot of tiny inlay work with a Foredom tool in a homemade router base, turned out of mahogany. I made a Plexiglas base for it and used carbide dental burrs I got from my dentist. Use a trim router to hog out the main recess for your casting.
Trace the outline, rout the recess, glue the casting in, and fill the surrounding recess with tinted epoxy.
My 2¢,
Re: Good advice, Bob
Bob Lang
Didn't you sign your stuff with a little inlaid rose? I remember seeing a picture a while ago and it was impressive.
Bob Lang
I had a template set of collars....
Many years ago I had a set of template collars for an old Stanley router. There was a collar and a ring that went on it. The concept was that the bit was an 1/8" and the collar was a 1/4". The ring that went on the collar was an 1/8" thick wall thickness, making the collar 1/2". The idea was you could make a template, say a butterfly patch, and cut the butter flu without the ring on the collar and then cut the patch with the ring on.
I'm thinking you could do the same thing if you had a bit and two guide bushings.
Re: I had a template set of collars....
Dan
Yes, I have one of those butterfly sets and I was studying on it trying to see if I could come up with a way to use it. Unfortunately, it's guide bushings are different from my other bushings so they aren't interchangable.
