welding wood *LINK*
welding wood *LINK*
welding wood *LINK*
Mark Hennebury
Who knew?
Wood Welding
by Myriam Drouin | Fresh Sparks
Linear wood welding (Source).
Thanks to research that started in Europe in the 90’s1 wood welding is now possible. This innovative process, that joins two pieces of wood without using adhesives or connectors, is obtained by inducing a linear or rotating mechanical friction, between two wood surfaces. The heat released by this friction causes the melting of lignin and hemicelluloses, two principal constituents of wood that then act as natural adhesives.
The strength of the welded joints is comparable to those with traditional wood adhesives. Wood welding, which is currently limited to interior uses, offers great potential, particularly for the furniture industry. The benefits of welding wood are many; this is a quick process that allows manufacturing wood products without any adhesives so therefore ecologic, economic and nontoxic.
The European studies, which focused mainly on oak, beech and spruce, lead to a collaboration between Le Centre de recherche sur le bois of Laval University, Le Centre de recherche industrielle du Québec (CRIQ) and FPInnovations to adapt this knowledge for sugar maple and yellow birch, two species greatly used in the furniture industry, notably through the doctoral work of Benoit Belleville. This research has resulted in the development of a prototype machine for wood welded panel production by Le CRIQ.
Linear wood welding. On the right X-ray image, dark pixels correspond to low density zones while pale pixels correspond to high density zones. (Sources: left image gauche (2) right image (3)).
High speed dowel welding. On the right image obtained by CT-Scan, the red zones represent highly densified zones while blue zones are references that correspond to wood density (Sources: left image (4); right image: Benoît Belleville).
Macro-trends: ecological manufacturing
Environmental Issues: reduced end of life pollution
Market Status: research stage, patents pending
Opportunity: To keep informed about this process please contact M. Yves Guérin, from le CRIQ at 1-800-667-2386 ext: 2431 (yves.guerin@criq.qc.ca ) or Benoît Belleville (benoit.belleville.1@ulaval.ca).
Sources:
1.Sutthoff B, Franz U, Hentschel H, Schaaf A (1996) Verfahren zum reibschweissartigen Fügen und Verbinden von Holz. Patent DE 19620273 C2. Deutsches Patent- und Markenamt.
2.Christelle Ganne-Chedéville. 2008. Soudage linéaire du bois : étude et compréhension des modifications physico-chimiques et développement d’une technologie d’assemblage innovante. Thèse de doctorat Université Henri-PoinCaré, Nancy, France. 234 p.
Welding wood video
Re: welding wood *LINK*
One can only suppose...
John in NM
That they are somehow using the wood's lignin as glue.
It's certainly a neat idea, and an amazing bit of technological research, but given how well the usual adhesives work, I can't really see it catching on.
Re: One can only suppose...
mdclor
If they can make it work for end to end joints, it might be the long awaited board stretcher we have all wanted at one time or another. :D
