Cutting a whiskey barrel. Ever try this?
Virgil Johnson
I need to cut a whiskey barrel in half vertically for the purpose of re purposing this thing into a base for a cabinet. The plan is to find the joints in the staves that are opposite each other that are closest to the center and perpendicular to the boards in the head of the barrel. First thing is to add a screw through the hoops at each stave. Is this barrel going to spring apart at the ends when the hoops are cut? I was wonder if I needed to screw the staves to the barrel head?
Re: Cutting a whiskey barrel. Ever try this?
Keith Newton
Yes, you probably will. In fact, you might ought to get some finish screws, and screw all of them to both the top and bottom. Otherwise, once you cut through the metal straps, everything will likely fall apart, and they are not easy to reassemble.
Re: And the answer is
Virgil Johnson
The staves of the barrel in the video look like they have a gap between them at the top where the rings has been removed. I think I'll add screws at the top and bottom.
