Minor glitch
Gary Smyth
In the process of rebuilding a pediment for a old chimney cabinet. For the final push before the end I glued up four 1x6 to complete a new top. It is a complete "dust" cover, not a frame as is the remainder of the top. All appeared right through the planing to 5/8 and edge treatment but when primer was added (both sides within a day) the bugger warped. Not a problem over time, but after some final sanding and smoothing I forgot how to best fasten the section shown to the remainder of this top. Do I fasten to the front and allow for wood expansion to the rear only, or fasten in the center of the side and allow for wood movement on both sides? The wood is poplar and the dimensions are approximately 18 x 26 inches. If center fastened the expansion would be nine inches on either side. Over time I believe that the wood will adjust to settle flat as only minor pressure is needed to push it down.
I intend to screw the top to the mating section not glue.
