Bink no7 spray gun problem
anthony siciliano
I have related this problem at MTF and have had several responses except that the answer to the problem wasn't among them. So I'm broadening my inquires, hoping someone else has experienced the same problem and fixed it. The issue is that my Binks no7, which has always been good to me (my Dad and I sprayed my 1940 Ford 4door sedan Lincoln Black Cherry back when I was 16, I'm 69 now). I hadn't used it in a while and I took it out to do some painting on a window I'm building. When I first pull back on the trigger to spray I get a nice fan (this depends on where the fan control is set of course) but within a few seconds it diminishes and just stops spraying paint altogether. If I release the trigger and then pull back the cycle repeats itself, the only way I can get a continuous stream is to set the fan control all the way to "round" and it works fairly well there. Here's what I've done and what I have. The compressor is a 30 gallon Craftsman, I've had at least 30 years (actually a Devilbiss) I just replaced the old regulator with a new one from Harbor Freight, this has not changed anything. I use a mechanical water and oil filter, then a desiccant filter downstream of that and another closer to the gun. I am using 3/8" hose, fairly new. I took the gun almost completely apart and put in all new seals etc from Binks Kit 6-188 along with a thorough cleaning. I say almost completely apart because at the base of the handle there are two threaded holes, one is the compressed air inlet the other has just a plug fitted to it. I had never taken this plug out because it wouldn't come out easily and not removing it never seemed to be detrimental to the gun's performance. But now I have taken it out and found that it led to a hollow passage in the handle. In there was a small wad of, what looks like steel wool, it was a bit rusty but fell right out. I never used steel wool on the gun but I did use Bronze Wool when I recently cleaned it. I didn't have time yesterday to reassemble the gun so I'll do that today to see what happens. Meanwhile does anyone have access to a cut away diagram of this gun so that I can better understand how it actually works and where the passages go??? Anyway thanks for looking and in advance of any scholarly replies!
Re: Bink no7 spray gun problem
Steve jenkins
You don't say what you are using to hold the product you are spraying. If it is a siphon cup there is a vent hole in the to that needs to be open to allow air into the cup as you siphon out the fluid.
hairyapple
That should have been in the post, the vent hole is clean, I wish it was that simple.Thanks for trying.
How about the packing on the metering rod *LINK*
Dick Coers
Did you pick out the old packing on the metering rod and replace it? They dry out either need a little vaseline or to be replaced. I'm talking about part #53 in the parts list. Also you often have to snug up the nut to make the seal. It has a bit of a taper on the nut #54 and that snugs the packing to the rod. Get it too tight and the rod won't move.
http://www.binks.com/Portals/0/Repository/77-1153-R25.1.pdf
do some experiments
If it doesn't spray either it isn't sucking up finish, the exit for the finish is plugged or you are not getting air flow. Do experiments to see if it is an air problem or a liquid problem.
1. Try water and see how it compares (is the problem a viscosity issue)
2. Try no liquid in the gun. Does the air flow change with time?
I don't know but if we are placing bets my bet is on the finish being too viscous.
Re: How about the packing on the metering rod
anthony siciliano
Yes that part #53 was replaced. The new one is some sort of plastic, the one I took out was plastic too. An old one that I kept for an emergency is made of graphite.
Re: do some experiments
anthony siciliano
I'll try the experiment with a dry cup, but I get the same result whether I'm using finish or just clear lacquer thinner. I always run some clear thinner through the gun after I've cleaned it and leave some in the cup so that things don't dry out in storage, as directed in the owner's manual.
Steve jenkins
It's starting sound like you are losing air pressure. What do you have the regulator set at and how long is the hose. That gun requires a substantial amount is cfm. If your regulator is only set for 35psi or so try cranking it up to 50.
anthony siciliano
50 lbs is my starting point usually. I'm using 3/8" hose, I never had this happen before so I don't think it's a hose issue, BTW it'd 25 feet on a reel. This is just some weirdness not easily explained. I had an older Body man down the road who grew up with this gun (I did too really, as I explained) who was always helpful. He explained for instance that the "sweet Spot" on the metering needle wold be found when I turned the screw back 4 1/2 turns from full stop. He is unfortunately no longer available so I need some new mentors. Thanks
Dick Coers
My sweet spot was 2, or 2 1/2 turns. But I likely used a tighter fan pattern than you. I always put a nick spot in the knob so I could keep track.
Problem solved Sherlock Holmes style.
anthony siciliano
I have a mark scratched into mine as well!
I took the gun completely apart again, and used a soft brass gun barrel brush to clean the tubes, then washed it ou and dried it. Reassembly with a cup full of "RAPID BRUSH CLEANER" Same result. So thinking back to Arthur Conan Doyle and Sherlock Holmes I remembered a famous quote. I paraphrase here " If, after consideration of all the obvious to no avail, then it must be something else, no matter how unlikely, that is the problem" I removed the new Harbor Freight desiccant filter from the line, then hooked the gun directly to the compressor sans hose and it worked just like it was a new gun, not one that is at least 55 years old. I haven't tried it with the hose yet because the filter filled in the gap between the compressor and my main line so I need to fix that first. Thanks for all the help and I hope to someday return the favor. I also posted on the architectural gallery one photo of a window I'm building for our house if anyone is interested.
