Some finishes by nature of their viscosity naturally form a thicker film, others a thinner film when hand applied. On factory furniture, the sprayed finish often is built up thicker than when a finisher I know sprays the same type of finish on the same type of furniture.
When you have a choice, do you prefer a thicker or thinner film, and why? Any idea why factory finishes are so thick?
That's a generalization that I have not seen. That said, factory finishes frequently contain the coloring as well as the clear coat. With these finishes the sprayer will lay on the number of coats to get the finish they need.
Film thickness has a number of variables. The viscosity, thickness build and the variability of the applicator will be a variable.
It's a misconception that film thickness determines the "toughness" of the resulting finish. A thicker film does not add materially to the ability of the finish to stand up to scratches, dings, etc.
I prefer thinner because I don't like my wood to feel and look like Formica. Factory finishes may be thicker because the public can associate it with quality (depends on marketing), or the wood sanding was done badly and the thick film can be smoothed easier than the wood. Many times the type of finish dictates the film thickness as it can not exceed what the chemical company requires. Too thick on pre catalyzed lacquer, and you get cold checking.
