cutting SS
cutting SS
cutting SS
mike mcnerney
I know it's a WW forum so I qualify, but I have to cut a stainless, 20 gauge range hood, shorter; 1 piece of a 2 piece telescoping type. Fortunatley it's the inside piece that will never be see. Last summer I rented and did cut some 20 gauge SS with a side grinder & a wheel that worked fine.
Some how I would prefer to use a jig saw? If someone thinks that's possible what kind of blade would you use?
MM
Re: cutting SS
Re: cutting SS
I would prefer to use something like a Makita metal shear.
You could probably do it w/ a tungsten carbide blade if you take it slow and use it at slow speed. If you have an air compressor, I would run a stream of air on the blade and the surface to cool the blade.
The big problem is that the blade really heats up. It destroys the temper on all of the HSS jigsaw blades so you have to use tungsten carbide.
But the blade is less expensive than a shear - though the shear cuts more neatly.
I ended up renting one when I had to do a lot of metal work.
Re: cutting SS
Re: cutting SS
20 Gauge SS? I would think you could cut this with tin snips. I have a pair of aviator snips that woudl do it nicely. They make left hand, right hand and straight cutting. The lefts and rights will both cut straight and in the preferred direction.
Re: cutting SS
Re: cutting SS
Stainless works fine buy any means.....providing you keep it cool. If it gets hot it hardens and what ever is cutting it will get dull or have its teeth ripped off. While I have not tried it I expect a hand hack saw will cut it fine and a saber saw won't unless you keep the cut flooded with coolant.
Re: cutting SS
PS....
An offset pair will make this easier.
Re: cutting SS
I would try this too...
John in NM
They'll dull quickly, but a good pair of shears (Wiss for example) should do it.
Failing that I prefer the angle grinder with a cuttoff wheel.
I once had a saber saw blade that was carbide grit instead of teeth, that might do it. Cutting 20 gauge with a saber saw is going to be pretty noisy and could leave a fairly nasty looking cut - that is why I'd go with the shears.
If one really wants to go top dollar, get a power nibbler. They work great and leave thousands of sharp little crescents on the floor :D
Re: cutting SS
Re: cutting SS
Dick Coers
I had never worked with stainless until starting in the model shop. It will surprise you just how hard it can be to work. Put a piece in the little bench shear that was the same thickness as steel, it would not sheer it. Not sure everyone giving the advice has actually worked with it, but luckily you do have a thin gauge to work with. It's not going to be real friendly to your tools, that's for sure. If you do use a cutoff wheel, get one made for cutting stainless.
Re: cutting SS
distrbd
Re: cutting SS
distrbd
The easiest way to cut stainless steel(as John mentioned)is to use cut-off wheels ,I highly recommend ZIP Wheel by Walter (thin cut-off wheels) with an angle grinder, I would just lightly grind on the line where the cut is supposed to be then go back and start cutting , please don't forget to wear a face shield and ear plugs.
https://www.walter.com/en_US/products/-/producttradename/abrasives/cutting/zip-wheel
Re: cutting SS
Re: cutting SS
I have never been very successful cutting SS with a jig saw or reciprocating saw, but I was usually cutting thicker stuff. The teeth would be gone in a short distance. Maybe if the speed could be slowed way down...
These days I use a plasma cutter, an incredibly useful addition to my little weld shop. Fasten a straight edge (or a heavy-gauge piece of bent wire for curves) and trace the line.
Without access to a plasma cutter, I would definitely go with cutoff wheels. You can get pretty thin ones for a side angle grinder. Don't forget good safety glasses, no, a full face shield!
Re: cutting SS
Re: cutting SS
mike mcnerney
Thanks all. I did use the cut off wheel last summer so I will probably go with that again.
cheers
Re: cutting SS
Re: cutting SS
Waltz
I have cut SS with my Bosch saber saw and a Bosch blade T118AHM the blades last longer if you cool the with cutting oil. It is a nasty job to clean up but it works.
Walta
