PC 335 trouble
PC 335 trouble
Kneale Brownson
PC 335 trouble
Kneale Brownson
Any BTDT regarding the PC 335 appearing to lose its drive. Motor spins, pad only spins if not engaged with the wood.
Re: PC 335 trouble
Re: PC 335 trouble
The PC 335 ROS uses an O ring as a drive belt. I bet yours is broken or missing. Easy fix. Might want to replace the bearings while you are at it.
Re: PC 335 trouble
Kneale Brownson
Re: PC 335 trouble
Kneale Brownson
Thanks, Barry. Bearings probably are a good idea, given this tool's age and use history.
Re: PC 335 trouble
Re: PC 335 trouble
I have several of those sanders. I have rebuilt both of them several times. When I buy parts I double up and buy a set of spares. I usually have a set of bearings and the O ring on hand. You can buy the bearings at a bearing shop and get better ones cheaper. Its been a while but as I recall the lower bearings fail faster than the upper one. Completely worth while to do.
