I repaired cutting board I made for my daughter ten or more years ago. She was using it and one of the kids put it in the dish washer. Anyway I have repaired it sanded off all the cut marks etc. I normally just use mineral oil and have her reapply when needed. This time I want to use the mineral oil wax combination I have seen post about. I was wondering the portions of oil and wax to mix up.
After you mix up the oil and wax (heated to melt the wax), let it cool. If the paste is too stiff/hard, remelt and add more oil; if too soft, add more paraffin.
Here is some info that should help. While the mixture calls for mineral oil and paraffin, substituting bees wax will work too. (I believe Howard's is mineral oil and beeswax). I prefer paraffin because it is a harder wax and maintains its protection somewhat longer.
An excellent treatment for wooden food preparation surfaces like cutting boards and butcher blocks is a mixture of mineral oil and either paraffin or beeswax. This is what is used on many commercial wood surfaces. It will last longer and be more protective than just mineral oil. Mineral oil can be found in most supermarkets in the pharmacy section or in a true pharmacy. Paraffin is found in the canning section of the store or in a hardware store.
Heat the oil in a double boiler and shave in some wax. The exact proportions are not critical--a 5-6 parts of oil to one part of wax will work fine. Stir the mixture until all the wax is liquefied. Apply the mixture heavily and let it set 10-12 hours or overnight. Next day do it again and continue until the wood will no longer absorb the finish. Let it set for 10-12 hours and then lightly scrape off any excess. Then buff it with a rag.
Reapply whenever the wood begins to look dry.
Never put a wood board in the dishwasher and don't soak it in dishwater for long periods.
is a mix of mineral oil, bees wax, and carnauba which is harder that paraffin.
Either way, I much prefer to first use an oil sealer such as Waterlox red-can before applying the oil/wax mix. The sealer cures under the surface and is more resistant to cleanings.
A waxed board looks nice and feels nice. If I was selling them I would be waxing. I just pour hot wax on the wood and melt it in with a hair drier. Buff when cool. But what a nuisance maintenance for a user "board".
Any board used regularly for what boards are used for is going to pick up oil and grease, which keep it from drying out unless assaulted by detergent. If mine do dry out I add any veggie oil at hand.
This procedure seems to alarm the modern "cook" who has never seen butcher blocks in use in days past before every aspect of life became a risk to fret over. As a reminder I add a picture of a butcher block in a butcher shop in Chianti, Italy, a place remote from the influence of California. The Italian customers seem to survive stuff cut on a block soaked with meat fat as all blocks once were.
sorry for late response but I have been deer hunting. Butcher block will be needed shortly
My home brew oil/wax mix is similar and I still have some from the last batch, so I haven't used the Howard's yet, but yes, I always use the Waterlox first, both on cutting boards and all "treenware" like turned salad bows etc. The oil/wax treatment will only penetrate so far, even on end-grain surfaces, and will be leached out in use. Soaking the surface with the sealer (I actually warm the wood in the oven first) gives me a more durable "finish" that resists water and food juices so the board dries quickly, cleans more easily, and is less likely to warp, cup, etc. over time.
Warm the piece to 120°, apply the sealer in wet-on-wet coats until it shows no dry spots, then wipe the surface dry and allow to cure for a week or more before applying the oil/wax.
Obviously you want to preserve the look of that thing with finish.
In our kitchen the cutting boards are plain wood. One started out with a sprayed finish that soon wore off. For the most part, the oil finishes do not penetrate as far as the hype suggests, unless there is exposed end grain. A good finish would be to soak the end grain in boat epoxy, and leave the rest raw. It isn't as though a partial finish is any good for anything.
