ADVERTISE HERE - FREE TRIAL
Lingerie Chest: Designing the Drawers
This is the start of the second stage in this build. Now that the carcase and drawer blades/runners are completed, it is time to start on the drawers.
The drawers are complex as they call for compound angles and dovetails. The design may be improved, and I welcome comments about this and the methodology.
This chapter provides a pictorial on the design and construction I have come up with so far. Pine is used in this test case (where Jarrah fronts and Tasmanian Oak sides will be used in the final build). However, the construction is for real.
The link is here (too many photos to post on the forum): http://www.inthewoodshop.com/Furniture/DesigningTheDrawers.html
Re: Lingerie Chest: Designing the Drawers
Sgian Dubh
Your solution seems to work, so why not just go with it. I suppose a challenge of throwing out your design questions for suggestions is you can end up with so many ideas, and it can be hard to decide which advice best suits your needs - I suppose there's a slight danger of the 'camel is horse designed by a committee' syndrome.
However, having said all that, I find it curious that you have just four dovetails at the back of your drawer box, and five lap dovetails at the front, which for that height of drawer box I find a little too busy at the front. I'd prefer just four wider dovetails at the front, also perhaps making the pins slightly more delicate, and I'd definitely reduce the chunkiness of the 'half' pin at top and bottom.
I guess that's my first contribution to the 'camel' committee, which you're more than welcome to ignore and/or dismiss, ha, ha. Slainte.
Hi Richard
That's what I want - constructive comments.
I think that there are too many dovetails as well. The plan is to increase the number as the drawers become larger, and that they might go 2, 2, 3, 3, 4, 4, etc. Perhaps 1, 1, 2, 2, etc instead. That would make one less on this drawer.
The final version will have very fine "London" dovetails. These were in Pine and I did not trust the wood to have enough resilience to survive! :)
Would you do the drawers differently? I am curious what others would do. This drawer was time consuming, but should speed up once I get underway. I needed to test the procedure to see if was doable. It was a bit easier than I visualised.
I did not realise that I had posted on the "power" side. I looked on the "handtool" side and could not find my post. Oh well - there is no difference as far as I am concerned. Thanks for the input.
Sgian Dubh
Derek, I'm not sure how I might do the drawers. I haven't thought very much about the technical challenge, but as I said in my last message, you seem to have found a workable solution you're comfortable with, so go with it.
I take your point about the number and the form of the dovetails. How you set them out, their width, spacing, etc, to satisfy the aesthetics is surely worked out best at the point of manufacture. That's my approach anyway, you may prefer a different methodology. Slainte.
This is not what you are asking, but yesterday I saw some furniture that had wildly bulging sides and fronts. For the life of me I can't think of the name of the style, something French? I was doing a home inspection and my client was following me closely. I sneaked a peak at the drawers and and they "faked" it. The drawer sides were set back a couple of inches and were square and conventional. Little plastic guides for the drawers. The drawer fronts were applied to complete the illusion. Department store furniture.
I have also seen the classic version where he sides were sculpted. Much more impressive.
Hi Barry
Yes, there are those with rectangular, straight-sided drawers - I agree, "fake".
The cabinets you refer to are a Bombe. Here is a Capen family Chippendale carved and figured mahogany bombe slant-front desk ...
A peek inside an 18th Century Swedish Chest ..
I thought it was Bombe, but I put that into Google and it came up with a WWII decoding machine. This time I put in Bombe furniture and got the results I was looking for. Is it supposed to have an accent over the e?
The curved drawer sides are much classier. Go for it.
