Face frame hinges Euro version.
Did not want to hijack BillP's post so I started a new one.
I am rescuing the kitchen cabinets in the house I am flipping. The cabinets were in pretty good shape but the doors were dated and beat to death. The drawers and runners were really tired, also, so I trashed the doors and drawers and rebuilt them. Also did one of the bathroom vanities. 50 doors and drawers. (If I had realized it was 50, I might have trashed the cabinets. too and started all over.)
the cabinets had the old Amerock hinges that used a T shaped slot to mount the hinges. I could not figure a good way to fill the slots, so I just left them and used the doors to cover them. I went to Lowe's and HD and looked at the hinges. Their version had a 5/8" overlap, so I built the doors 1 1/4" bigger than the openings in both directions. 5/8" would have been perfect to hide the old slots.
My oldest friend runs a cabinet shop and I got him to finish the doors for me. White. Had the painter spray the old brown cabinets white. My fried drilled the holes for the hinges. He had a source for the hinges that was about half the price of the borgs.
Then comes the problem. When it comes to Euro hinges, I am an ignorant savage. Am I the only one that finds them bewilderingly complex? The hinges I ended up with were basically a half inch over lay and cold be adjusted to about 9/16". In a few cases the doors over lapped in the center and I had to mortise the hinges back into the styles. This turned into a blessing in disguise. It helped to cover the old slots. But it was a PITA.
These hinges were "demount-able". Oh yeah?!! I need a lesson in remounting them. I don't have enough fingers and toes. There has got to be a trick to it this savage does not know. Where are the Illuminotie when you need them?
Learned or relearned two or three things. Buy the hinges first and know what you are working with. Practice on a mock up. Find a way to label the parts. With fifty drawer fronts and doors, it got a little confusing. Get some touch up paint, because there will be a touch up. Get a college degree in Euro Hinges. You should see the one for the Lazy Susan door. It works, but Damned if I understand it. Get some good friends. He did a fabulous job on the finish.
Oh, the right drawer runner is different than the left one. I was about six drawers in before I noticed. And the pulls came without screws. Looks like they might have mentioned they were metric. Did I mention that after forty years of doing this stuff I am back in the steep part of the learning curve?
Re: Face frame hinges Euro version.
Jerry Roberts
Barry, I too have the same problems with Euro hinges. I've wanted to use them but I have yet to find anywhere as how to measure and install the little buggers. Also I understand there are many different kind of hinges. I don't know what to look for as to overlay or insert or anything like that. The ones I've looked at don't have any good instructions with them and asking anyone at the box stores is useless. Can anyone suggest as to where I can find good info and instructions ? Thanks for any help.
T the 32mm system was not designed for faceframe
Keith Newton
If you want to make life easier for yourself, you need to leave them off. Then it is a simple matter of drilling the holes in the sides of the cabinets for the hinge mounting plates, slides, and shelf pins. They all use the same standard backset of 37mm from the front edge of the carcass, so with a good template, you don't even have to measure lots of things, you just drill the holes, and ALL of hardware uses the same standard holes.
I made up a bunch of templates back in the mid eighties for base and upper cabinets out of 1/2" apple ply with all the holes drilled 18mm, for use with a plunge router mounted with a bushing of that size. I had to get 10mm to 1/2" bushings to adapt the standard 5mm Brad point drills to work in the routers.
With this simple setup, I can drill the holes at 1.5 per second, or put another way, 90 per minute, which is about as fast as a $200,000 CNC router back then, and I was only asking about $200 for them back then.
For some reason, I couldn't get any of the locals to give up their old ways. They only wanted to keep doing what they had always done. I still have a few of them, so next time you need th knock out some cabinets, let me know and I'll send you one.
TomD
The ones I am familiar with have three modes of adjustment. There are three screws. The one deepest into the cabinet, works in a slot back and forth, and is for adjusting the hinge projection, I like to have the doors about 1/8" from the box.. You simply hold the door, loosen both of these screws in the two hinges, and then the door simply slides out for quick removal. This also seems to be the feature that most often works loose and needs tightening. The doors don't seem to fall off when they are loose.
The other two adjustments are one screw on a vertical dovetail slide. You hold the door, loosen both of these screws (each hinge) and the door is free to side up and down.
The remaining screw is the most sophisticated as to the mechanics of the adjuster, but simplest to use, and to some extent each hinge can be adjusted independently with this adjustment. The remaining screw, is hidden under the opening mechanism, you may need to go through this piece to reach it underneath. You simply twist the screw in or out, and what happens is that you can control skew of the door. You probably need to make an adjustment, then close the door and check for skew, and parallel gaps with any adjacent doors. If you adjust this screw one at a time, or adjust the top and bottom in opposite directions you will adjust the skew, but if you adjust the top and the bottom in the same direction, you will adjust the left/right position of a door.
Once you find these tree adjustments you will be able to adjust the doors for even gaps and to coplanar.
Keith is right
Dick Coers
Face frames have always been an issue with this system. The hinges either set the door too far off the face frame, or have some adjustment compromise. But the overall system is a dream for adjustment compared to conventional hinges. Cheap knockoffs aren't going to help either. Having the hardware before doing anything has always been the best possible situation, not after you build and paint. I don't think you can blame the hinges here Barry, imagine hanging 50 doors on butt hinges! There you are talking time!
don stephan
My suspicion is that every manufacturer's brand of Euro hinges and mounting plates is different, except for the 32 mm distance. As suggested already, I would never get something so complex from a big box store. The only way I could stay comfortable with them was to first make a set of well labelled sample installs using pairs of 6" x 6" x 3/4" pieces of plywood. And I only used one brand I was able to buy locally from a cabinet supply business.
Re: Keith is right
You are correct. This would have been a bear with butt hinges. My mistake was looking at one version/brand of the hinges and then using a different brand.
These hinges are amazingly complex to me and yet very attractive because of the adjust ability. Assuming you get the dimensions correct to start with, they are actually very easy to install.
The terminology is baffling. Back set, overlay, full overlay. But once you grasp it, they are very versatile.
I think of a hinge as some device that pivots around a pin. These don't do that. So in some respect they are not hinges at all.
They are not elegant on a face frame, because they project into the cabinet. But, I was stuck with the face frames because they were already there.
I went to the web site for the brand of hinges I got, (Salice) but the web site was all knees and elbows and seemed to be set up for people that already thoroughly understood the hinges. I need the beginner version. I tried You Tube also, but you have to be careful there. Things seem to be posted by Idiots and Geniuses. Hard to sort them out.
Because of the complexity of the hinges I assumed they would fail early. My friend tells me Salice invented them and they are very durable and have a lifetime guarantee. I am still skeptical. I originally looked at Blum hinges. I thought they were THE name brand.
Re: Keith is right
Dick Coers
The big boys are Blum, Grass, and Salice. You did not buy 2nd grade hardware. I bought into the Grass program when I was in business from 1987 to 1995 because they would give me a drill/installation machine with a fair sized order. My kitchen is going on 25 years old, same hinges as the day they were installed. I used the 165 degree opening angle. These things were huge, but I really wanted the wide angle. Can't see that mass when the door is closed! I have used a spacer board behind the face frame to flush it up, and mimic a frameless installation. To me it looked cleaner than the base plate style that hangs into the box. With frameless style of hinges, it's easy to get 3/4" overlap. Overlap is acheived with baseplates, and or crank in the hinge. Shoot me an email if you get stumped.
Jerry Roberts
Once the hinge is mounted, adjusting and positioning the door should not be difficult and I also know it takes a 35mm hole to mount it in. Once I find this info out I feel it would be easy to make a template. My problem is ,exactly how far from the edge is the hole drilled and the same with the screw holes. About a year ago I went to a box store and told the guy I wanted to try euro hinges. He asked what kind of doors .I asked does it matter? He said, yep. I assumed the hinges were different for inset and overlay doors. Right or wrong? Sorry to be so ignorant .
Dick Coers
You can get hinges that are for inset, half overlay, and full overlay. You can also use full overlay with two different heights of base plates to make them half overlay and inset. You can also get hinges for thicker doors, and many different opening angles. The outside profile on the door is a concern as well. Too strong of detail and the cup hole may break out. You can tweak overlay with the drilling distance off the edge. I usually drilled so the edge of the hole was 5mm from the edge of the door. I think you can go as thin as 3mm.
Jerry, I am certainly no expert but I will share what little I know.
You can drill the cup with a 35mm bit or an 1 3/8" bit. Very nearly identical.
The edge of the hole is about 3/16" from the edge of the door and about 3/8" deep. You can easily check the depth on the hinges you buy.
I have done a few on my drill press. A friend of my son runs a cabinet shop that uses lots of these hinges. He made me a piece of MDF with two holes drilled in it. I use that as a pattern and set it on my DP table and bring the quill down with the bit in the chuck and into the hole and then clamp a long straight edge behind it. Then I set my door in place and clamp a stop block onto the fence to position the holes left and right. You could do the same set up without a pattern by putting a 3/16" spacer between the bit and the fence. Once you get the fence clamped and the stops in place, set the depth on the DP and drill away.
The Pro's have a set up that drills a pair of 10mm holes, one on each side of the cup. (3/8" may work too.) The hinges come with plastic insert screwed onto them and you press them into the holes. At least you could if you were set up to do it. I was not. What I did was remove the plastic inserts and use half inch screws (No. 6?) I put the back plate on the hinges and put them in the "shut" position in the cup holes. To get them properly lined up I just put a straight edge behind them parallel tot eh edge of the door, mimicking the face frame. The straight edge must be long enough to bear on both hinges at the same time. This will be much easier to understand once you look at the hinges and set them into the door. What this does in line everything up so that the holes in the hinges are parallel to the edge of the door. Then use a self centering bit (Vix Bit or is it a Bix bit?) to start the screw hole for the hinge. Then drive the screws.
Then I used a spacer or set block to space the bottom hinge of the floor of the cabinet. You can use a back plate as a template to guide your Vix bit. Screw the bottom hinge to the frame and then do the top one.
Some of these hinges will use round holes in the attachment plate and have three dimensional internal adjustment. To me these are excellent and make the Vix Bit a Godsend. Others have elongated slots in the back plate and you slide the whole hinge up and down. I have some of them also, but don't like them as well because I invariably get the screw in the wrong end of the slot.
Some of the hinges have De-mountable back plates. I can take them apart and put them back together until I install the hinges. Just can't do it with the door in my way, at least not on the Salice hinges.
In spite of being very complicated, these hinges are very versatile and useful. Get some and play with them.
Jerry Roberts
WOW Barry. I'm going to print your reply so I don't forget. I'm good at that. Thanks a bunch!
You are welcome. There is much to know about these hinges. Many variations. As somebody mentioned there are different amounts of swing in addition to various overlays. And there are soft close versions. It goes on and on. The basics I posted above with get you started and tend to apply to to most of them.
