A55 Smoothing Plane
windows 10
windows 10
windows 10
Jerry Gibbs
I have 8.1. I have trouble with updates. I tried using the problem solver for updates and get nowhere. Should I get the computer fixed or download 10. I am wary of any change but will if it makes sense. Jerry
Re: windows 10
Re: windows 10
Bill Howatt
If you are having trouble with Windows Updates you may have trouble going to W10 since it is presented as an update.
Have you done the update fix that downloads the file: WindowsUpdateDiagnostic.diagcab ?
If you can get it downloaded and installed which will register your PC as a W10 PC and are still having trouble, you can then do a clean install of W10 by downloading the W10 installation package.
I heard the major update to W10 that is coming (or maybe some already have it) will let you do a clean install from W7 or W8 just by using that product's serial number. If so, that is an option if the update method doesn't work.
Bill
Re: windows 10
Re: windows 10
Jerry Gibbs
thanks, I will try that
Re: windows 10
Re: windows 10
Hoa in Alameda
What kind of "troubles" are you experiencing? If a particular update can't be installed on you PC for whatever reason, exclude it from the update. Don't do "automatic update." Rather, choose the updates you want to apply.
My PC at work runs Win 7. There is a particular update that keeps failing. It's been like that for probably 4 months. I just ignore it.
For the most part, updating to Win 10, especially from Win 8 or 8.1, is pretty simple. But before updating, search to make sure the software packages you are using work under Win 10. I have a particular software from Cisco that refused to work under Win10 on one of my home PCs. I haven't updated all of my home PCs for that reason.
Re: windows 10
Re: windows 10
don stephan
It's not clear to me if you are having trouble with all updates or those for a particular program, and what the problem is (downloading, executing, . . .)
Re: windows 10
Re: windows 10
Jerry Gibbs
When I try to automatically download and install all of the available updates, after a long time of downloading and installing, a re-boot is required. At this point the computer says some of the installs did not work and undoes the entire lot. This is for windows 8.1 in general, not a specific program. The computer will not indicate what updates failed or accept the ones that did not fail. I am using Hoa's approach of individually installing the updates. It may take several hockey games to do this. Jerry
Re: windows 10
Re: windows 10 *LINK*
John McGaw
Try the idea suggested in the link. Any update events/failures should be kept in the system log.
Reading Update Log
Re: windows 10
Before installing Win10..
Jerry Nicholson
.. I suggest you do some research on how Microsoft monitors the activity on your computer when you use Win 10. Microsoft seems to want to watch everything we do. You can turn off most of this stuff but you have to go through a long list of check boxes in more than one place. You could try reading Microsoft's EULA but I understand that it has many many pages. I tried the free upgrade from Win 7 to Win 10 on one of my computers but there were several things that I didn't like and I flushed it. For instance to get fast boot times it apparently does some kind of hibernation that doesn't un-mount NTFS disk volumes. This will keep those volumes from being accessed by other operating systems. On my primary computers I dual boot Win 7 and Linux Mint 17.
Jerry
Re: windows 10
ebd
Re: windows 10
ebd
It's not only software but also hardware drivers that are not ready or will never be implimented (legacy hardware).
