Shaky hands question.....
This may be OT, but it affects my wood working. My hands are shaking more than they used to. More so my right than my left and I am right handed. Pretty sure its not Parkinson's or even essential tremor. Just enough to make it difficult to insert a driver bit into a Phillip's screw. Used to be easy. I am 66. I think many of us here are of a certain age and may have similar experience. I am wondering if there are exercises that might improve the steadiness?
Re: Shaky hands question.....
BobStev
It might be Parkinsons, and is certainly worth a trip to your doctor to find out. I have a friend that just developed early onset Parkinsons at 67, not sure exactly why it was early onset at 67 but that's a different discussion. Go to your doctor and find out why.
Adam of Oakland
Re: Shaky hands question..... *LINK*
Adam of Oakland
No way is this off topic! We all rely on our hands!
I'd echo Bob's input that it's best to see a neurologist. I'm 44 and i've got an essential tremor, it's from mom's side of the family. There are meds that might work, not always. Medtronic corp. makes a device that can help too. You might want to visit the essential tremmor foundation website, just to see, if you haven't already: http://www.essentialtremor.org/about-et/
Gary Smyth
At the great risk of receiving pushback from others on this forum. This is a medical question and not a woodworking one. What you have is a symptom. No matter how many others here may or may not have experience similar to yours, I’d venture that no one that responds can properly identify the source of your particular problem with certainty. Don’t waste time here. Locate a medical professional and get a definitive answer if not a cure. Brain/muscle coordination is not something to wait on. Better to know quickly and work toward your solution.
I must agree with Gary
Big ditto
See a neurologist - get tested. Get a proper diagnosis and treatment course.
No pushback here
Excellent point, Gary. While we have just about every area of expertise covered here, health concerns ultimately should only be discussed directly with your doctor. This is why those TV commercials for pharmaceuticals have those long, gory disclaimers at the end.
In a meta context, I think the forum concept is being validated here. I've always maintained that it is the multiplicity of opinions and experiences expressed on a forum that gives perspective to the original question. Gary, your wise words are exactly the kind of advice that makes this venue so worthwhile. Thank you for the important reality check.
Ellis Walentine, Host
Hank Knight
Barry,
I agree completely with Gary, too. FWIW, however, i developed a tremor beginning about ten years ago (I'm 71). I started noticing it first in my handwriting, which has now become a scrawl. Oddly enough, it doesn't bother me much in the shop. Most of the time I'm able to brace my hands/arms against the work, the bench or the tool to steady myself. That's all I need and the tremor is not much of a problem. I did see my doctor about it and confirmed it is "essential tremor" and not Parkinsons or worse - which was a relief. Go see your doc. The peace of mind is worth the trip.
Hank
Joseph Mulherin
I, too, have developed this malady but it has not got in the way of my working yet, just typing is most noted.
"meta" is a big word for this forum
Curt Putnam
I agree with all the advice to get advice from your doctor and not us. There are some drugs which can and do help - mysoline being one such.
Jack Guzman from Maine
I agree,you should get a doctor's advice.
However,I have shaky hands,have for 50 years now. It comes and goes and doctors have never found a reason for it. I'm also particularly sensitive to caffeine.
The shaking doesn't bother me when I am woodworking. I can paint a window sash,but I have to move quickly and in one smooth motion. For delicate details I steady my arm on something. You learn how to get around difficulties. It is part of woodworking.
My writing is illegible and I can't draw a straight line but I build windsor chairs. It is mostly hand work and my unsteady hands never cause a problem.
I hope this helps.---Jack
Chuck
Don't tell everyone that you have shaky hands, Just tell them that you're "Quick"!
Martin S.
My father's hands shake. His doctor said it was related to some medicine he is taking. Might be worth it to check with your regular doctor and ask if any medications you are on might be causing the shaking.
FWIW, my dad was checked for Parkinson's, and found to be negative, so it is his meds.
Just wanted to post, since no one else presented this particular possible cause.
Bruce, a MN Galoot
I have fine motor control and stiffness problems in my fingers due to medications. Writing is a near impossibility.
Martin S.
Same as my dad. I have to write his checks, and he signs them, but just barely.
clay foster
I've had an essential tremor all my life, but a few years ago I had to start taking a medicine that greatly exacerbates it. It's worse in the morning. If a job requires a tool needing more finesse than a hammer, I don't even go there.
Thanks Everyone.....
I understand I should go to a doctor and I will. Just wanted to get a read on the situation and find out how common my situation is. It seems I am a lot better off than some here. Part of the problem was to find out what kind of doctor to approach. I presented my GP with a problem with my elbow. Some sort of minor deformity with a puffy place around it, probably from crawling around under houses. His answer was, It will either get better or a lot worse. If it gets a lot worse, we will have a surgeon look at it. Its better, but not as good as new, but at my age, nothing is as good as new.
Re: No pushback here
TomD
I think the question got redefined below, but as the OP posed it, he was asking about exercises, which could yield an answer in one of two directions. Woodworking related exercises that either as techniques or practice elements to improve results. My hands at 56 are still steady as a rock, so I have little to add, but might there not be suggestions such as improving work holding so one could more commonly access both hands; maybe issues around tool sizing, like handle size, etc...
Or medically, there is a possible answer to the question that does not involve online diagnosis. If none of the range of possible maladies responds to exercises, then there is that. Doesn't imply the making of a diagnosis. It is reasonable in the run up to what could be a fair amount of time to get a medical answer to ask whether the is any possible light at the end of the tunnel.
In my escapades with heart disease, there is just that kind of hope. Exercise and diet are very helpful. Neurologically, not so sure. Even heart failure can be addressed through diet and exercise. A diagnosis of "heart failure" (what moron thought that term up) may be treatable.
http://www.livestrong.com/article/475004-exercise-for-an-essential-tremor/
Kent B
Re: Thanks Everyone.....
Kent B
Late to the party...
Barry - sorry about your situation.
You want to go to your GP for sure - he/she knows you the best, and can direct you to the proper specialist as/if needed.
That is how I have had a couple situations that turned out to be "latent serious" dealt with, before the edge of the precipice.
Re: Ditto. See your GP
It may be splitting hairs but I don't think it pays to delay an accurate diagnosis from a qualified medical practitioner. I had sinusitis, chronically, for more than two years, and I tried all kinds of homeopathic approaches, mostly because I was leery of the CT scan they wanted to do on my head. Finally, after none of my remedies worked, I went for the scan, and my doctor pointed out that I had a very serious situation in my sinuses (I hope not because of 50 years of woodworking) that required surgery, which I had seven weeks ago. I'm glad I did, because my condition was still treatable. I don't know what Barry's exact syndrome is, but it could be something easily identified and treated, and time could be a factor. Better safe than sorry. Not that exercise, especially documented successful regimes, can't be of great value, but I wouldn't necessarily recommend it as an alternative to prompt diagnosis.
Jesse Cloud
Agree with you on not delaying a prompt diagnosis.
BTW, I had that sinus operation too. My surgeon said that woodworkers have paid for his last two boats.
That, and the disgusting two weeks of blood and snot flowing into the "mustache bandage" after the operation, have greatly increased my motivation to avoid wood dust.
