Veritas - Innovation in Tools
Stair Risers
Stair Risers
Stair Risers
Dustmaker Mike
I really am doing some wood working. I am getting ready to redo my stairs, getting rid of the old carpet and replacing it with Oak treads and risers. I found red oak treads for a pretty good price. The risers on the other hand seem way out of line in cost. So being as cheap as I am I figured I could just use 3/4 oak ply and cut them to size on the TS. So my question is will this work instead of glued up boards? Just the risers not the treads.
Thanks Mike
Re: Stair Risers
Re: Stair Risers
David Yoho
Sure, it would work but I would think over time there's a good chance the veneer might get damaged from toe and heel wear.
One way to do it on the cheap might be to use 1/2-inch plywood as a base covered with 1/4-inch oak. You could resaw some 3/4-inch or thicker oak and get more mileage from the expense of the oak.
Re: Stair Risers
Re: Stair Risers
John McGaw
Probably overkill but, if you find the treads to be reasonably priced, couldn't you just buy twice as many and cut half of them down to be risers? I don't know what having 5/4 risers would do for the construction process but they should last forever.
Me, I was super cheap and when I touched up my stairs I just sanded and stained the treads fstl and then covered the risers with super-thin painted hardboard. It looks good and will probably last longer than I do.
Re: Stair Risers
Re: Stair Risers
don stephan
My expectation is the grain pattern on the plywood will look very out of place alongside solid wood treads. And I've often seem complaints that plywood and solid wood of the same species do not look the same after staining and applying finish.
Re: Stair Risers
Depends on veneer
Dick Coers
As long as you don't get rotary cut veneer, it will look exactly like the solid stock. I've never done any stair work, so can't give you any advice on the construction.
Re: Stair Risers
Re: Depends on veneer
Dick is correct. Rotary cut veneer does not look like anything that was cut at a sawmill, but you can get plywood that has any "face" you want. Quartersawn, book matched, slip matched, whatever. OTOH, you might no like the price.
I agree with the idea it might get beat up on the risers. Repeated heal scuffs might cut right through the veneer.
Where are you? You might find a local guy with a mill that woudl sell you some air dried oak at a more reasonable price.
If you use plywood you might be able to leave the original risers in palce and just cover them with 1/4" ply.
The borgs sell kits to cover existing stairs. I have not looked at them closely. Wonder what they use for risers?
Re: Stair Risers
Thanks not sure about heel
Dustmaker Mike
The treads will be bull nosed and hang over a little bit, so heels and such should not be a problem. I thought about resawing some 1 by 8 to get double the material. I might use poplar and just paint it white I have to run that by the boss first.
She will let me know what to do.
Thanks again
Re: Stair Risers
Paint is the word
Dustmaker Mike
she said to paint it. So no ply wood. I am using preprimed pine.
