Hinge name
Hinge name
Kneale Brownson
Hinge name
Kneale Brownson
What's this shape of hinge called? Where can I get a more heavy duty version?
Re: Hinge name
Half offset hinge...
John in NM
Where to get a heavier one is anyone's guess. Depends on how heavy and what you want to use it for.
Re: Hinge name
Look up hospital hinge
Gary Smyth
If I'm correct these wrap the door all the way around the side of the cabinet. Stanley makes them but so do others. You will have to search for heavy duty, but it won't be difficult.
Re: Hinge name
Re: Look up hospital hinge
Richard McComas
I call them institutional hinges.
https://www.google.com/search?q=institutional+hinges&tbm=isch&tbo=u&source=univ&sa=X&ved=0CE4QsARqFQoTCNj5y6yKnckCFQWZiAodTf8EWQ&biw=1280&bih=613
Re: Hinge name
Re: Half offset hinge...
John Veerkamp
Allows a door to open fully so that the entire door frame is open for clearance. My wheel chair bound brother has them on all of his house doors. Any place that has hardware for handicap access will cary them.
Re: Hinge name
Re: Hinge name
Greg
If I might paraphrase Crocodile Dundee, "That's not the hinge you want, this is the hinge you want."
I installed a set of these at my brother's house after he was confined to a wheelchair for a period of time after a cycling accident. It allowed him to pass through a doorway that had previously been too narrow due to the door itself being in the way.
http://www.accessibleconstruction.com/services/beds/13b.html
Re: Hinge name
Kneale Brownson
Re: Hinge name:  swingaway hinge
Kneale Brownson
That's the term I need. This is for a sewing cabinet, not a full-size door. Thanks for the help.
