Some days woodworking leads to other places. Over time, I've accumulated enough tools that are missing bolts and screws with odd threads (#10-28? 5/16-20?) that it's time to figure out how to thread screws, ideally thumbscrews.
I can find dies in those sizes - http://www.victornet.com/subdepartments/Special-Pitch-Dies-up-to-1-2/1350.html - and there are videos on actually using it, though the videos tend to show larger bolts.
The hard question is where to find stock to use for screws. I don't especially want to make the heads of the screws in particular. I can find blank #10 screws - http://www.brownells.com/gunsmith-tools-supplies/small-hardware/metal-screws/blank-screw-kit-prod376.aspx - but I'm not sure that's the best approach. I've heard people talk about re-threading screws rather than starting from scratch, but that sounds like it might have its own complications.
Any suggestions for stock to use for the screws? Any warnings about doing this wrong?
You can typically just run a standard tap in and get away with it - 10-24 in place of 10-28, works well for short holes especially. Alternatively I've also gone the next size up 12-24 or 1/4-20 in a pinch.
The #10/28 screw needs to be deeper in than I can get a 10/24 or 10/32 screw, and the 5/16-20 is the only screw holding a bit in place. 1/4-20 falls out at inconvenient times - not while I'm drilling, but when I move the brace and the bit falls to the floor.
I'm sorry, I wasn't clear - I meant run a 10-24 or 5/16-18 tap in first If you want perfect, you have to go up a size first, but sometimes you can get away with re-threading the hole for a more readily available size.
Granted, you may not want to alter these tools, which I would also understand completely.
but no, I don't really want to change the tools. One is a Stanley 78, not a super-special tool but old, and the other is a funky brace and bit I definitely shouldn't change.
(The brace came with a 1/4-20 thumbscrew, mostly good for dropping bits.)
I'm kind of surprised there's no machine shop fishing for these kinds of searches and making expensive screws on demand. St. James Bay Tool Company has had the screw for the #78 in the past, but doesn't seem to have them in stock now. Still, it's odd how few suppliers there are, and that it's easier to find taps and dies than screws.
Without a metal cutting lathe, I might start with an existing screw/bolt with a minor diameter close to the major diameter of the thread you need, mount it in something that turns (wood lathe, drill press, electric drill) and use a file to make it the right diameter for the die. The die will clean up small irregularities. It is usually best to start with something longer than you need.
For special things you can often fasten a threaded shaft to something else by welding or drilling and tapping a hole and screwing and holding the shaft with superglue. I recently repaired a broken thumbscrew for my honey gate this way by gluing in a length of brass threaded rod.
Also, I like to buy assortments just to have on hand. At the moment I have enough for seven lifetimes. I can usually find something in this collection that fits or at least can be modified.
Perhaps you have a business nearby like we do that stocks every possible threaded thing I've ever asked for. They cater mostly to industry but will sell to anyone, even me.
One more place to check: a local metal recycling/scrap place keeps a trailer full of bolts and nuts. I've found fine-threaded stainless specialty bolts 1/2" in diameter! This place sells all this by the pound, just like scrap steel. Maybe you have one like this near? Take a thread gauge.
Is it time to get a metal cutting lathe?! I can't believe the things a small metal lathe and milling machine (and welding equipment) let me do. These open a whole new dimension in creating and fixing. A small used lathe can be pretty cheap. (Before I bought a larger lathe I found an old Unimat metal lathe at an estate sale so cheap it was almost free. I made lots of things from aluminum, brass, and steel with this tiny lathe.)
With most metal lathes you can even cut external threads on anything and any way you like, with shoulders, short, long. You have way more control than using a die.
I have lathes and mills, and taps, or can thread some screws right on the machine. What do you need? I should say screwmaking is a regular thing for gunsmiths, so any local smith or machine shop should be able to do it. If you just need a couple no charge, except maybe postage, depends how nasty that gets.
If you want to make the threads yourself, I can make the studs. Again, have two pages of unfinished large jobs with the number of jobs accumulating faster than the jobs are getting done, but if you just have a few tools that need a little help...
Actually, you should be able to set a Taig up for threading fairly easily, if they sell gears for the pitches you want to do - that might be the ifffy part.
You can get carbide inserts for thread cutting and a tool holder for them, far easier than learning to grind HSS cutters for threading - the HSS is far cheaper though, if you're up for tool grinding. It's not that hard really, just got to sneak up on the right profile - I made fine pitch acme jam nuts for my drill press by grinding my own cutter.
As far as I know the Taig doesn't have a gear head, though someone is probably making or selling it.
A solution many have implemented on similar machines is to set them up for CNC. There is a fairly standard application for that, though nothing around CNC is all that easy or cheap, unless you can do your own programing, machining, electronics and so forth.
On specialty that dove into that is the Multimachine. About as crazy as it gets in a world where they are giving away Bridgeports for peanuts.
Good for you. One thing out there, not sure it works for your purpose is that LV is selling some rather nie thumbscrew heads in brass. They are pre-tapped, and so you can insert any piece of threaded stud you want and you have a complete thumb screw. I bought one to replace a thumb screw in a galled out marking gage.
The way both Taig's and Sherlines are set up (and others I'm sure), one just mixes and matches gears outboard of the pulley to get the desired thread pitch. While Taig themselves may not produce gear sets, as you say, there is lots of aftermarket support. So in the pics where I've seen it done, it could well have been a home made setup. While not a super easy proposition, the accessibility of the drive pulley and lead screw ends make it feasible with just a little imagination.
