Making precise measurements/cuts
Jesse Cloud
I had an "Ahah!" moment in the shop this afternoon and thought the idea might be useful to others. It worked well for me.
I had backed myself into a situation where I needed to remove exactly 0.06 inches from each side of a 30 inch panel. Yes, I know, not getting into this situation in the first place would have been the smart thing, but ....
I've been using an old deck of playing cards for shims for years. Well, I took my best caliper, set it to 0.06 inches, and locked it. Then I stuck playing cards into the cap until I had enough for a snug fit. It was five, but thats not generalizable.
So I set my tablesaw fence to the original size (by placing the board between the blade and the fence), the clamped a board to the table, snug against the far side of the fence.
Loosen the fence, insert the cards between fence and clamped board, snug up fence and make the cut.
For the next 0.06 inches, take the cards out, snug up the board, clamp and repeat the process above.
The cut worked beautifully. exactly 0.12 inches removed and the centerline is still the center.
I thought about adding this to the 1/64th markings on a ruler thread, but it was already awfully long.
