Flatening un-flat blades and bits
Flatening the Router Plane bit
PIC 1 Router plane
The router plane is a handy tool to have on hand. It excels at making flat bottom excavations of precise depth, like for a hinge mortise. As usual Lee Valley has recreated the Stanley version of this tool with better function.
PIC 2
I had hoped to use this plane to establish the to be glued face of the bridle joint (more on that adventure later).
There is little I enjoy less than preparing a cutting blade when it arrives rusted, pitted, misshapen or unflat from the flea market. Fortunately Lee Valley has removed this tedium from most new blades bought from them by accurately flattening and refining the cutting surfaces during manufacturing. They forget this useful service on the router plane. Its bit was rounded at the tip and the surface finish had not been refined past initial shaping. Thus, the tedious process of getting the cutting surfaces flat began.
PIC 3 cast iron plate
The challenge is to keep the surfaces from rounding while flattening. I started with a fine fixed diamond plate. This “stone” quickly removed the rough grinding marks but the misshapen top surface was going to require significant material removal. I switched to a cast iron plate charged with 30 micron diamond paste and lubed with WD 40. It has been a while since I used this plate and I had forgotten how much faster it removes metal than other abrasives. All the black junk on the plate is router bit metal.
For flatening, consider 30 micron diamond on cast iron. For bridle joints on curved surfaces consider something other than the router plane. More later if I am successful.
PS I have no idea why my color pictures posted black and white. sorry
Re: Flatening un-flat blades and bits
Bill White
Bill, are those irons compatible with the #71 Stanley?
I need a spear point for my 71.
Bill
Re: Flatening un-flat blades and bits *LINK*
Bob Entwisle in NJ
Bill,
Yes, according to Lee Valley those will for the Stanley #71.
I've included a link to the page on their web site.
Bob in NJ
http://www.leevalley.com/US/Wood/page.aspx?p=52609&cat=1,41182,48945&ap=1
Bill White
Thanks Bob.
Re: Not necesarry
TomD
Technically since at least the blade on mine has a relief angle this step was unnecessary. The edge geometry can still be affected by the back, but a micro bevel could deal with that.
I actually prefer the spear point when possible, I get to just north of the edge, then simple use the point which is always at the same height, to slice out a perfect depth shaving.
Re: Another sharpening method
Mine was the classic case of not wanting to take the time doing a hollow pre-grind taking times longer having avoided this useful step. I dd not at first see how much the tip of the new blade was rounder. Like you, I do like hollow ground blades.
I never considered using the sanding cylinders for hollow grinding. I have charged loose diamond on aluminum cylinders. I need to try the sanding cylinders....thanks
Re: 1x36/42 belt sander, the real dope
TomD
Guys have ground swords on those, and the abrasives LV sells for them, and others, are pro grade. The LV sander is actually pretty good also. Actually, as far as eating a sword is concerned, about the only limitation is the abrasive quality and the power of the motor. Both of which are underspecified on most machines, and laughable on drums. Nice thing about belts is that belt speed is driven from the drive wheel, the cutting wheel is an idler, so it churns out the same speeds regardless of diameter. I actually have a wheel for my 2x72 that has a 3/8" diameter for cutting out bicycle rack tubing (though in that case a file is actually better).
I converted my drums into contact wheel for my 2x belt sander.
There is a tiny bit of a move away from 2x belts in the knife world, the 1" is that good.
