Demilune-veneering the skirt
Veneering the skirt
PIC 1 assembly
Somewhere under there is the veneer being glued to the skirt. I have a lot of clamps and add as many as will fit.
PIC 2 parts
The gluing sandwich consists of the caul, frugally sawed from the serpentine drawer waste, stiff rubber gasket material, a piece of paper to soak up glue and moisture, veneer and finally the skirt. The caul is sawed so that it is slightly flexible under clamp pressure to aid conformation around the skirt arc while applying lots of pressure. I use white glue. If is squeezes through the crotch veneer, something that usually happens with commercial veneer (mine I sawed) it will not affect subsequent staining. The Headley shop uses white glue exclusively for this kind of veneering. If it works for them its good for me.
