How to cut it
How to cut it
How to cut it
Ed
I have a piece of wood that measures 12" X 8" and is 69" long. I want to cut it into an "L" shape leaving the short 8" leg 2" thick and the long 12" leg 3" thick and keeping it 69" long. Basically, I want to cut a 10" X 5" chunk out of it. My plan is to mount this "L" shaped piece as my fire place mantle.
Any idea how to cut it?
Thanks,
Ed
Re: How to cut it
Re: How to cut it
Denny
How about using a bandsaw, cut off a 2 x 8 and then a 3 x 10 and glue them back together into the L shape?
Denny
Re: How to cut it
Re: How to cut it
I have a homemade Bow saw and would just use that. My bandsaw would handle it but it would take a second person or some sort of support to hold the long end.
Re: How to cut it
Re: How to cut it
mdclor
I agree with John and the band saw, but you could also use a chain saw, or 2 hand saws-rip and cross cut if you have them.
Re: How to cut it
alternative
Can you mount some rods in the wall, drill the whole thing and hang it? I have done several mantels this way with good success.
Re: How to cut it
Jack Guzman from Maine
Beam saw
See if your local tool rental has a beam saw. It is a portable circular saw made for timber framing having a 15" blade. Two easy cuts and you're done. Otherwise I think your best bet is careful cuts with a chain saw. At least that is how I would approach this project.---Jack
Re: How to cut it
2nd Alternative
cut your 12x3 first
next rip an 8 x3
Cut a 45° on one edge of each and then glue up the "L" with the glue joint hidden by the "mitre's edge.
If your table saw won't cut the thickness at 45°, cut what you can and then go to the jointer with the fence set at an accurate 45° to finish.
Re: How to cut it
ebd
Re: Beam saw
ebd
+1 for the beam saw. My brother in law has a beam saw and it would do this job perfectly in a few minutes. Would certainly be worth renting one.
I've got a 12" Stihl arborists saw that would also do the job, though less perfectly and would require some hand planing to get a finished surface.
