200+ woodworking book reviews
Demilune-tidying up a detail
PIC 1
The result of the brick laying leaves white poplar on each side of the drawer, that space between the drawer and where the bridle jointed leg will be located. This space must be walnut. What to do? It is easily filled with a 1/8” thick walnut “veneer”. First I chiseled out a space for this filler. Learning some hand tool skills has been of great advantage in solving problems like this one. This operation took a minute at most for each side.
PIC 2
Pic 3
I carefully fit an 1/8” piece of quarter grain walnut into the excavated space and glued it in place. After the arc is smoothed it looks like it grew there. The leg will be fit with a bridle joint and lap the left side of this veneer piece, leaving 7/8" walnut showing on the sides of the drawer.
This added piece of walnut presents end grain to the drawer opening, a typical situation for a drawer set into a skirt. Alan reported below a problem with this end grain chipping on his table, a worrisome situation to be considered. I will have more to say about this possibility after I do a bit or research. Stay tuned.
Re: Demilune-tidying up a detail
I was wondering about he little area of poplar exposed tot he left and right of the filler, that are not fair with the surface. I am guessing the leg/bridle joint will cover that area, actually requiring a rabbet or slot front and back on the apron. did I get that right?
As far as the end grain and chipping goes on the ends of the drawer opening....
It seems to me one solution would be to angle the opening so that the contact or wear surface woudl be behind the veneer of surface of the opening. 1 or 2 degrees should be enough leaving a tidy little gap. This way the drawer never drags on the opening. And if you bevel the opening just enough, the wear surface will be the base material rather than the veneer.
On the few drawers I ever cock beaded, I back beveled the cock beading about three degrees to slide into the opening and almost close the apparent gap.
Brian Holcombe
Thanks for posting this up Bill, I'm enjoying! Nice work!
"Nice work!" We will know that if/when the legs are successfully mounted. Will be down hill from that part on.
