I know virtually nothing about compressed air fittings, but I am upgrading my compressed air lines from 1/4" to 3/8" fittings to have better pressure over a long distance. However, there are a few items that I want to leave at 1/4" like a 23G pin nailer. Is there a quick release connector that is 3/8"male on one end and 1/4" female on the other end? Or will I have to cobble something together? Thanks.
You could get a 3 way manifold that plugs directly to the compressor fitting. Have 1 or 2 fitted with a 3/8 connector and the 3rd one 1/4. Or you could insert the manifold anywhere in line. Just a thought.
but the volume of air moving through the system may increase depending on your compressor's ability to keep up and the connector size.
You haven't said what compressor you have. With a smaller pancake or 2-3 gal unit, you may find that you get less performance because the compressor has to work harder to keep up with the volume demand. The size of the air line is not so important, but the two parts of the quick-connects must match. You can get connectors termed "hi-flow" which have a larger i/d for more air flow.
You can use the smaller fittings with a larger hose if you haven't bought the hose yet. Since 1/4" npt fittings are the most common larger diameter hose tends to be available with the smaller threaded ends.
The pressure reduction you see is really resistance to flow over a long run of hose, smaller ratio of volume to surface area inside the hose means greater friction and thus reduced flow. A few 1/4" neck downs in a run won't cause any problem since they are a drop in the bucket of the overall ratio of volume to surface area.
Now if you already have all your 3/8" hose and stuff, all with 3/8" quick disconnect fittings - push lock as they are typically called - then you may need to look for a few that have the right combination of npt size and quick disconnect size to do what you want. You should be able to find it without resorting to reducing unions and stuff, though that is always an easy option. Adapting unions for npt fittings are easy to find at the local hardware store or home center. Best to get the brass ones as we all know our tools don't much care for rust in the air supply.
What you've shown is carbon steel. Used for oil and gas but not compressed air because of the water vapor content of compressed air will corrode the fitting. Should be brass/bronze.
I have the same compressor. Mine is piped with 1/2" copper to service points in the basement shop and garage where 3/8" hoses are fed through regulators and filters. I use hi-flow couplings.
Actually, that T is NPSM on two of the three legs. Different system (never used it myself, so I don't know much about it).
What you would need is something like this:
From the McMaster page though, it looks like you can easily get 1/4" quick connects with a 3/8 npt end. Probably can find them at a local place too if you know what you're after.
Maybe take some pics of what you have, or measure the npt fittings, that should be enough to figure it out. Most air tools use the same size IIRC, though I couldn't tell you if its 1/4 npt or 3/8. If the ones on the hoses are the same size then it's pretty easy.
I would run bigger lines through the shop then end at a 1/4" quick disconnect. I use 1/2" through the walls to outlets spaced around the shop, and have a long 3/8" line on a Goodyear reel in my maintenance bays. It has a 1/4" quick disconnect on the end.
I don't think you will see any advantage to using 3/8" quick disconnects on anything unless you have a very high flow need such as a big sand blaster. All my air tools use 1/4" quick disconnect fittings and everything works fine.
I use a short piece of air line (whip) like these on most of my air tools. Several advantages: one it has a swivel and doesn't restrict tool position it tight places, two, it is smaller diameter and MUCH more flexible than my heavy air hose, three, it moves the bulky quick connect fitting a few feet away from the back of the tool.
Also, for connecting things to air lines I love these. I use them at the end of all my air lines. You push the button to release safely and gracefully.
- Reduces possibility of damage to property or personal injury
- Double click to engage properly; first click lock coupler and plug; second click engages the air pressure
- To disconnect push the button twice: first push relieves the air pressure; second push disengages the plug from the coupler
I buy these at the local Northern Tool. I have found a few cheaply made fittings that don't connect properly to these but good quality brass fittings always work.
Also, if you buy brass quick connect fittings at Home Depot, etc, look closely - some have a small gap near the end and some don't. Those without the gap need to have the outer sleeve pulled back with one hand while pushing the male part to connect. The kind with the gap doesn't require pulling back the sleeve. I use these exclusively on air outlets so I can attach a hose with one hand, especially handy when the outlet is high on the wall.
Thanks for all suggestions. I guess I shouldn't have gotten all the 3/8" fittings, but I have them now so I'll keep them. However, I won't go crazy trying to change any more out.
I worked as a Mfg. Engineer in an industrial plant for near 40 years. The plant (built in the early 1960's) had a "loop" system for the air distribution. This was a carbon steel 6" or 8" pipe that ran from the bank of compressors (Three 100 / 125 HP) from the rear of the plant and split to run toward the outer perimeter of the plant from the front to the rear of the plant, then joined in a loop ~ over 1000 foot. All of the drop lines were steel pipe. We had over 1,000 air powered cylinders in operation. All were piped with steel pipe. I have been in many industrial plants during my life, all were piped with steel. I don't recall ANY issues IE: corrosion causing failure, rust in our filter system etc in all my years. I can't say Stainless steel or Brass may not provide a little cleaner air but I have steel in my shop and have had zero issues in about 10 years. I doubt any manufactures would spend the money for exotic materials as steel has been used successfully for many years. I do have a good water separation, filter and regulator system where I connect my spray guns.
"I do have a good water separation, filter and regulator system where I connect my spray guns. "
but in a home shop system that may, at any given time, have a significant amount of condensate present in the receiver and laying in the lines as well as water vapor, it's always been recommended to me by techs and installers to not use iron-bearing fittings. The increased cost for a dozen or so fittings in a home shop is far less a consideration than it would be in an industrial plant.
My compressor is fitted with an auto-drain plus my hard lines terminate with drip-legs, coalescing filters, and drains so, absent putting in a real powered drier, I have good dry air to use everywhere. Since Merl hasn't provided specs on how his system is set up and maintained, my advice was based on the side of caution, especially since his photo example was of a flair fitting.
That it was galvanized pipe with an hardening thread sealant. If one were careful about it, there is no reason this wouldn't work, and is probably the most inexpensive method for a safe pressure pipe system.
I could see a factory taking the time and trouble to do galvanized well - the cost savings on material for a large job would be well worth it.
in that setting as it is very durable, especially where exposure to being bumped by moving equipment is a big factor, the failure scenario is by pin-hole rather than explosive rupture, and both the material and maintenance are less expensive.
I have a QualSpray (QS614FR) regulator/filter after ~40' of 3/4" black pipe from the compressor. The purpose of the steel pipe is a heat sink to cause any moisture to condense before it gets to the filter and I have a drop immediately before the filter. The piping is either vertical or slopes at about 1/8"/foot. There is rust inside the pipe, but I have never had any issues. Maybe that was because I was living in the desert SW and possibly things will change now that I am in humid NoVA.
Anyhow, I successfully sprayed 1 coat of Target's EM1000 today. I plan to do 3 coats of EM6000 tomorrow to complete the vanities.
Once a year I take it apart to clean and lube with synthetic grease. Just be aware that if your compressor is in a cold space, the drain (and the water in the receiver) will freeze and clog in the winter. Mine's in the garage that won't freeze until the outside temps drop below 15° for more than a few days. That's when I fire up the space heaters to keep the garage beer from freezing
I'd switch the black pipe for either galvanized or copper, but as long as you're not getting rust in the output air then the filter is doing its job and the pipe material is a minor point.
Personally, I have no trouble draining a tank now and then, but that's just me. One thing I do often do is put a street elbow, extender pipe and ball valve on the drain to make it easy to do.
I've had my auto drain in place for 10-12 years with its discharge through a 1/4" plastic tube on to a spot on the floor. I have noticed that the condensate seems to have eroded that concrete floor surface a bit which tells me that the condensate tends to have a pH on the acidic side of the scale. I use only top-line synthetic compressor oil and change it every 6 months. Wonder what the pH would be with cheaper oil that has a tendency to carbonize the compressor valves etc.
John, I did the bottom drain thing and use it at the end of the day when the compressor has run. Normally, that is only when I have been spraying because brad & pin nailers don't use much air.
Thanks, Mark, I use the po'boy method described by John. I drain it into an aluminum pan and let it evaporate, but that may be a thing of the past. It is in the basement so freezing isn't an issue, hopefully.
