Demilune -Band Sawing the skirt
Band sawing
I don’t get out much and I don’t have a band saw book so I don’t know how common it is for people to saw the way I do. I recently helped an experienced woodworker to saw a complex shape and he was bewildered by my technique. Klutz that I am about many things I can band saw to a line, leaving a profile that is easily smoothed to a fair curve. (note: PIC 1 is a test cut)
PIC 1
What I do will be familiar to turners who ride the bevel of their tool to aid control of the cut. I ride the back of the band saw blade against the kerf behind the teeth. I then pivot the work piece off this pivot point (the back edge of the bade) to control where the teeth are cutting. On an outside curve any error results in a cut drifting to the waste side of the line. If the cut drifts outside the line I back up a fraction of an inch, adjust the teeth location by pivoting off the back of the blade and resume cutting. For someone watching it looks like I am taking 4 steps forward and one step back as I progress around the curve.
PIC 2
The result is a curve that is easily smoothed with a hand plane, file, or coarse sand paper, something that will be described in more detail in a subsequent post. You can see in Picture 2 the black marks that result from the back edge of the blade rubbing on the kerf.
