Geometry
Geometry
Geometry
Joe in a Cleveland suburb
In the video below, the video creator, Graham, makes a simple Shaker bench. In the video he uses a divider to lay out the design on the legs and the brackets.
I would really like to learn how to do what he did with the divider so I can lay out the same design. I've watched the video over and over and over. Pausing it trying to write down the steps. I can't get it though. There are some points where I can't tell how he set the divider. And it's difficult to catch measurements and so on.
I am most interested in the legs(?). Can somebody explain how to do this? Or, what is this shape or design called? Maybe if I knew what it is called, I can find a solution by Googling it. How to do it is probably out there, just don't know what to search for.
https://youtu.be/BwRcOvU6eVA?list=LL1hYpVCndelmiGUvh8Lx2kQ
Grahams videos are fun to watch. I've asked him directly about this and he said he might make a video on doing it. Guess he never had time to do it.
Thanks.
(math and geometry challenged. oh, and finishing challenged... )
Re: Geometry
Re: Geometry
BrianMonumentCO
Joe,
He is quite entertaining, with the variable speed.
I particularly like his "power sander" and "power drill".
Some of the use of the divider appears to be to construct a line perpendicular to another line.
In this operation the setting of the divider is not important. Should be enough to make a significant line.
Look at the kahn academy entry for "constructing a perpendicular line using a compass".
This explains the procedure well.
Re: Geometry
Re: Geometry
JoeW, Detroit
Set the dividers so they are more than half the length of your line. Start at one end and strike one arc above the line line and one arc below the line. Place dividers at other end of line (do not adjust dividers) and strike two more arcs. One above and one below. The arcs above will intersect and the arcs below will intersect. Draw a line from one arc intersection to the other intersection.
Re: Geometry
Foot note
JoeW, Detroit
I think the directions I gave are for a perpendicular bisector of the line. You would need to calculate were to layout your endpoints if the line needs to be else were but the middle.
Re: Geometry
Re: Geometry
He is laying out an OGEE curve. Google "Laying out an ogee curve" and you will find many references and one of them should turn on the light for you. If it doesn't, I can walk you through it, but it would be much easier to watch
Re: Geometry
Re: Geometry
Video downloads consume too much of my limited internet so I didn't watch it. But if it is an Ogee an article in Pop Wood by the design person showed how to lay it out. If you can't find the article email me and maybe I can. there is a good chance I have the copy in a heap of Pop Wood back issues.
In general lay out a grid of points (x-y axis) on a piece of paper, or use graph paper where the grid points are spaced the radius of the arcs apart. So if the radius of the arcs of the ogee (which is just two semicircles mated at an end) is 1 " lay out a grid spaced 1" apart. Two of these points on the grid will be the centers of the two arcs that make the ogee.
Re: Geometry
Boot jack leg
Dick Coers
Barry is right and that is called an ogee cutout, but pretty sure the traditional name for that style of leg is called a boot jack. Reference is to the the piece of wood by the front door that let you hook the heel of your boot in it and pull off the boot without bending over.
Re: Geometry
Re: Geometry
Yonak
JoeW is right. Most of the marking he is doing is making perpendicular bisectors. The reason he is doing that is so that, when he makes the arcs for the ogee curve, the inside and outside arcs meet at the same place on the construction line by locating the focus end of the dividers on the perpendicular bisector. He never changes the set-up of the dividers and that's why it works out.
Re: Geometry
Re: Geometry
TomD
As a guy who was on dial-up way longer than he should have been, I quite understand, but you would go nuts on youtube, Bill, if you could get there. Entirely worth it, way better than what is out commercially in many cases.
Re: Geometry
Thanks! I get it now.
Thanks guys. You all sent me down the right path.
I get it now.
It's actually pretty simple to do.
Thanks a ton.
Joe
