Adhesive/caulking recommendation needed
Howardd
I am replacing capacitors on my Italian made bandsaw and a have a round wire going thru a rubber grommet in an aluminum junction box.
I can't find a grommet that will provide a tight fit in the aluminum wall or a tight fit between the grommet and the wire. The ID of the grommet is about 1/16 inch greater than the OD of the wire.
What adhesive could be used to seal the spaces between the rubber grommet and the aluminum junction box and the space between the wire and the grommet?
Thanks
Howard
Re: Adhesive/caulking recommendation needed
Pure Silicone - Black or Clear
I agree, silicon RTV
Silicone.... But?
John in NM
Why does it need sealing at all? What was there before?
Rubber grommets are typically a tight fit on the metal part and a loose fit on the wire. Their purpose is to prevent a sharp metal edge from cutting the wire insulation, not to act as a strain relief.
The ammonia in silicone can cause problems with copper alloy metals. Should be ok with aluminum, but don't use it on brass, bronze, or copper.
Re: Silicone.... But?
Howardd
Replacement wires are larger than original wires so I need to get different grommets and cannot find grommets with exact fit.
Howardd
Need tight fit between wire and grommet to prevent airborne wood dust from getting into connection box.
Shim stock
Tom Dunlap
Duct tape?
Electricians tape?
Tom
Re: Shim stock
Chuck
How about Plumbers Putty?
your chemistry is amiss
There is no ammonia in silicone. The crosslinking reaction is by displacement of an acetyl yielding acetic acid. The smell as you surely know is acetic acid not ammonia. OK now fess up and tell us what you have been doing to get that confused tonight?
The grommets are
Brian Roberts
for wire abrasion protection....not to keep dust out.
While a little dust migrating in may disturb you....it won't be a problem.....there should be no ignition source....or you have other problems!
Re: your chemistry is amiss
Thanks Bill, I was thoroughly confused. My chemistry is not nearly as good as yours but I was thinking, Ammonia? I thought it was vinegar/ How much vinegar woudl it take to completely cover the smell of ammonia? Then I was wondering if I had gone nose blind or my memory had failed.
I understand the grommets are there to for abrasion resistance to keep any sharp metal edges from cutting into the wires, but they will also help to keep the dust out.
My experience is keeping the dust out is a good idea. Dust got into the switch for my Performax. It got into the contacts and it became glitchy. I bought a new one and installed it. With nothing to lose I took the old one apart and dumped the dust out. It was packed. Was a good location for a better sealed switch. Or one so wide open the dust would fall out or you could blow it out.
You're right!
John in NM
Working all day on rebuilding a porch. Cold in the morning shade, hot in the afternoon sun, with plenty of winter glare :D
Vinegar also attacks copper and brass, I suppose being acidic and copper alloys being fairly reactive. I doubt it does so as quickly as ammonia though, just remembered that the stinky RTV silicone and brass are a no-go. Pretty sure I've used it on aluminum with no ill effects, but I wouldn't argue much if someone claimed it corroded also.
Dusty switch and RTV
Interesting. The same thing happened to the ON/OFF switch on my Jet 1642 lathe. The thing just quit one day and on disassembly it was full of dust. Once I cleaned it out (not easy) I used plastic wrap and tape to prevent that from happening again. After your report I think I'll do some pre-emptive sealing on my 22-44. (I LOVE that thing!)
One curious thing about RTV - it is a great insulator when cured but before that the acetic acid evidently makes it a good conductor. To our shocked embarassment my associate and I discovered that one day in the research lab when we displayed insufficient patience after "insulating" some 110v AC terminals! Fortunately nothing was injured other than pride.
Silicone alternatives to a grommet
Indeed acetic acid can attack copper with vengeance. It is actually the combination of oxygen and acetic acid that is essential. In fact acetic acid is commonly refined in copper equipment, but oxygen must be excluded. Aluminum is passivated by an oxide layer and will be less affected.
E6000 and the various "Goop" products are alternatives to silicone. Several turns of duct tape or electrical tape might do fine also. Or make a grommet from wood and glue it in place. An auto body parts store likely has a grommet that will fit. Look for a store that sells body paint. Those multitude of drawers with parts at Lowes and Tractor supply may contain a grommet.
Re: The grommets are
Brian Roberts
And ...of course I am referring to the enclosure for a capacitor....not a switch.
Jason Roehl in Lafayette, IN
Keeping dust out is a good idea. While there isn't a direct ignition source, if a junction box gets caked full of dust, the wires can be over-insulated, trapping more heat, even enough to start melting things, and well, then there's a bunch of fuel there in the form of dust...
Ask Ellis about it.
Jason
Re: Silicone alternatives to a grommet
You can also find a grommet that is a little too big to fit in the hole and cut a slice out of it to make it fit.
I once bought a big grommet assortment and can almost always find one that is perfect. For a small wire through a large hole I once resorted to gluing a smaller grommet inside a large one.
Or....
John in NM
Several layers of heat shrink tubing over the wire to bulk it up and fit snugly in the grommet....
Or even that silicone tape stuff that LV sells. I was pretty skeptical of that stuff until I arrived at the new job in June and used some here (wider than what you get at LV but the same stuff). We have it for building strain relief on ganged fiber optic cables that are not being used in the industry approved manner. That tape really does stick to itself forming almost a solid rubber "tube" around whatever you wrap it around.
I think I would try that tape first, if I were willing to wait for it to arrive.
Of course, if one has a tube of silicone handy....
