Hand Screw Clamp Tip
David Yoho
For those that haven't thought of using wooden Handscrew clamps to solve a similar problem in the shop, here's an idea worth keeping stashed away until needed.
THE PROBLEM - I was beginning the finishing stage for a king size headboard and wanted to apply the clear coat to both front and back at one time. I didn't want to lay it on one side, do the other, wait until dry, and flip it over. I needed a way to stand it up so it wouldn't tip while working on it, which would allow me to apply finish all the way around it.
THE SOLUTION - Clamping a pair of Handscrew clamps to the bottom of each post provided the stability I needed and I was able to apply finish to both sides in one go.
Once I have completed the back I can lay it on my bench to finish the front side and the spots where the clamps were. The picture below shows what I'm talking about.
Re: Hand Screw Clamp Tip
Kent B
Kent B
Clever. Can use that - thanks.
I also use the handscrews at the DP, when I have a small or oddly-shaped part I need to put a hole in. Clamp it in the handscrew, and then use one of the DP table's clamps to hold the handscrew..
chandler
Handscrews rock.
Ron in Sterling, CT
Great Tip David. I also use a Hand Screw to hold a window upright while I finish/paint window sash.
Ron
Jack Guzman from Maine
Good tip David. I love hand screw clamps. I keep one set with a V cut into each jaw to hold round objects.---Jack
dave dircksen
Another idea is to bore a hole in the end of each post, put a dowel in the end and a matching foot piece then you can finish the whole thing.
