Lawnmower deck woe
Lawnmower deck woe
Lawnmower deck woe
Tom
In an earlier post I was asking about winterizing my lawn mower deck. Well After pulling it off I found a major rust through. I am thinking about attempting to cut out the old and weld in a patch. But I was wondering how to determine the gauge of metal I need? Would measuring a none rusty area with a caliper do it? Also where would be a good source for metal? Since it is wood I am a bit lost!!!
Re: Lawnmower deck woe
Bill Howatt
yes, you can measure with a caliper and then you can Google for a table to convert to metal gauge number for the thickness if you want.
If it is rusted out and you plan on welding you may be cutting out a fair area to get something good enough to weld to. Also, welding thin steel requires more skill than thicker steel.
How elegant a repair do you want it to be? You can get some fairly heavy galvanized steel from a place that does furnace work and install it with some screws. The main thing is to block the holes. Fiberglass can be used as well.
The other thing to consider is if the damaged area is located where there may be some mechanical strength considerations such as pulley/blade mounts and shafts.
Bill
Tom
Found some pieces in my barn of the same thickness! Now I am off to mt brother-in-law to borrow a mig welder. The repair will be totally utilitarian!! Not a thing of beauty!!!!!!
Alternative
sand the paint off the outside for several inches in "sound" metal around the hole. Cut your patch to match and bend for decent contact.. Instead of trying to weld thin stock braze on your patch with fluxed bronze rod. Less heat required and no melting burn-through in the thin steel. BTDT.
Pop rivets and metal adhesive
Dick Coers
I'd forget about the welding. I'd stop by an auto body supply and get some metal adhesive. About half the parts on cars these days are held together with adhesive and limited welding. You could pull it down with a couple of pop rivets. If one spot is rusted through, you likely have other thin areas. This patch will give you a little more time. Unless of course this is in a structural area. Then welding is appropriate.
Re: Pop rivets and metal adhesive
Do you know what kind of metal adhesive this is, perhaps a brand name? I'd like to read about it - sounds very useful.
I have done the welding sheet metal over sheet metal thing. It wasn't too difficult and I got no burn through with even thin gauge if I welded as a series of tacks with mig. Better was gas welding with a small torch but that was trickier to learn. I have tig now which is what I would reach for first.
I had a pickup with a rusted out bed at the fenders. I crudely cleaned the area and coated it with fiberglass from some sort of cheap kit. Again, crude, but functional. It lasted longer than the rest of the truck. Someone restoring a truck would have been horrified but I was going for function, not beauty. I spread it far enough to arrest the surrounding rust.
So, what are you looking for, restoration or practical?
Ralph Lipeles
While you are trying to decide which repair approach is best, start hunting for another deck. There is a lot of stuff out there. This summer, after over a year of searching, I found a deck for my 1965 Jacobsen Chief tractor. Good hunting and good luck with the repair.
Ditto on the brazing.
Tim Greif - West of Chicago
Brazing is a good alternative for thin metal. Think of it as soldering with bronze. Not quite as good as welding, but more than sufficient for your needs. Good strong bond with virtually no chance of burning holes through thin stock.
Thomas E Norton
Decided to have a "real' welding shop donthe repairs!
Re: 3M panel bonding adhesive
kencombs
I've used similar, there are several brands. When done correctly, you can actually tear the metal before the adhesive will release. But, a good fit and clean metal is essential. I wouldn't be afraid of it, even in a structural area. But, be forewarned, it's more expensive than welding supplies!
I wonder if the mower deck can be patched with stainless steel. I bought a reel of mig wire for welding stainless to carbon steel.
Unless I can find a stainless 55 gal drum I plan to weld a band of stainless sheet metal around the bottom section of the next burn barrel I make. They always rust out there in s few years. Love that plasma cutter!
