Demilune - Bricking the Skirt
Engineering strategy- Normally a demilune skirt is assembled by one means of another and then the face veneered. Were it not for the drawer I would do likewise. In my case I will assemble the skirt in such a way that the drawer opening will be part of the assembly process and the wood between the front legs will be walnut and not require veneering. The wood behind the front legs will be poplar and require veneering after the skirt is assembled.
Conventionally the skirt substrate is laid up from segments of poplar like bricks and then the half moon skirt is sawed from this bricked assembly. You are going to see some strange shaped “bricks” in the pictures, which invites explanation. Recently some serpentine drawer fronts were sawed from poplar. I discovered to my frugal delight that these shapes would make my bricks except for the walnut parts.
PIC 1 brick material
PIC 2 Bricking the first layer
Bricks are laid on the pattern to determine their orientation so that the final assembly will yield the skirt after band sawing. In my case the ends of the bricks for the first and last layer are splined at their ends to add strength to the assembly. You can see these splines in this picture.
The ends of the “whale shaped” thick poplar pieces will define the drawer opening. It’s angle is determine from the pattern. It’s orientation is transferred to the bottom brick layer and defined by the tape. It is then a simple matter to align the 2nd brick layer with the table edge.
PIC 3 planing the brick end
The angled end of these bricks were hand sawed to a line and then the cut refined and smoothed on the most useful shooting board.
PIC 4 last brick layer
It is essential to keep the layers of this assembly in a plane. To achieve this goal I assembled the last layer on the table saw and 100 pounds of lead applied the “clamp pressure”.
And the result after bad sawing the outer circle
Re: Demilune - Bricking the Skirt
correction- tape not table
in the paragraph that begins "whale shape" at the end it should read "tape" edge not "table" edge. What was I thinking!?! Well it was near lunch.
Looking good, Bill
It's very helpful to show progress shots as you've done here. Looks like a fine table in the works.
