Keeping my paint/spray from freezing
Terry Alexander
I have 2 large shops but I also have a separate 8x12 small building that I store gasoline, chemicals (I have a very large farm) and my paint in. This spring I went to get some chemicals to spray on the farm and it is obvious that they had frozen and were now useless (can you say wasted $$$$). I am wondering if there is some kind of device our there where if the temperature goes below freezing, it would turn on a 150 watt light bulb. I tried searching the internet....but I am pretty inept at that. I found a lot of thermostats!!!
As always...thanks in advance!
Terry Alexander in West Texas
Re: Keeping my paint/spray from freezing
Any little heating thermostat should do that.
Or just buy a little barn heater with its own stat and use that. You can buy them for 25 or 30 dollars which is not much more than a stat and bulb would cost and it might be more reliable. If the bulb burns out you are out of luck. I always used two bulbs in such an application. Getting harder and harder to find bulbs that put out heat.
Yikes, I know what you mean by $$$$. I think 2.5 gal concentrate of 2-4,D and gly-4 are pushing $100.
I just found this thermostat at Amazon, looks so useful I just ordered one. Has a lot of positive reviews. You set the temperature and plug in a 110v light, heater, etc.
http://www.amazon.com/gp/product/B000E7NYY8
A passive way which would be work but operate for free might be geothermal heating. I put in a waterer for my horses that uses a 12" pipe sunk 4' into the ground. (This one is deeper what was required - they want 36" here where the frost line is 18".) Ground temperature here in TN is about 54 deg (I think) year around and the convection heat from the ground keeps the supply pipe and the tank from freezing. (If you have livestock I'm telling you what you already know, but someone else might be interested.) The room or cabinet would have to be pretty well insulated but it would work even if no power was available. Or build a small root cellar/storm shelter for the chemicals!
Incandescent bulbs and controller
I bought a lifetime supply of incandescents from Amazon at a good price. Get em while you can!
A heat lamp from the local farm store (or smaller bulbs made for reptiles) would also work for a heat source. For raising fowl I put them on a dimmer and so far they have never burned out. I like your idea of using two bulbs - a friend lost 40 chicks once when a bulb burned out.
I'm building a honey warmer that uses lightbulbs in an insulated cooler to liquify honey that has crystalized. This page describes a wired-in temperature controller that should work for any application.
http://www.beegeek.com/filepage/files/Build%20a%20Great%20Honey%20Heater.pdf
Re: Keeping my paint/spray from freezing *LINK*
Dick Coers
A couple of old chest freezers make good cold storage units. Easy to heat. If you want another option for a remote thermostat, check this one. It has a really low setting option. Of course look for a cheaper source, Grainger isn't know for being the low cost option.
http://www.grainger.com/product/COLUMBUS-ELECTRIC-Line-Volt-Mechanical-Tstat-2E817?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/2E817_AS01?$smthumb$
Re: Incandescent bulbs and controller
My son uses some sort of heating pads to keep his reptiles warm. It would do the job. If you want I can ask him for details.
The Freezer idea is a good one.
curbside recycling
Tom Dunlap
Like someone else suggested...an old fridge/freezer. They're available every day out on the curb. Since you don't need to cooling just the box, you're set to jet.
Make some shelving to fit your containers, fill it with your chemicals. Then, add jugs of water to fill up the rest of the air space. The water becomes a 'heat sink' and will moderate the temp in the fridge.
I do this when my fridge or freezer starts to empty. Since a filled freezer/fridge has less air the food or water displace air, which is NOT a heat storage medium.
A light bulb and thermostat inside will keep the fridge/freezer from freezing.
Tom
John Veerkamp
Farm and home stores have in line plug in thermo's. used in well houses and poultry buildings. They turn on at @33 and off @ 40. They also have heat lamps. Cheap and traditional on the farm.
Bill Howatt
I made an insulated cupboard with a surplus 140W heating element to store apples and potatoes in a very cold location.
I put a wireless thermometer sending unit in it and I have the receiver in a location where I see it frequently just to keep an eye on the temperature. This probably wouldn't work in a metal fridge or freezer box.
Bill
Kneale Brownson
Use at least two bulbs
Kneale Brownson
You don't want one to fail and cause the same problem you already have.
Ralph Lipeles
They make heating "tape" usually used to keep pipes from freezing. It is about 3/4" wide, thin and comes in lengths usually multiples of 25'. There is a built-in thermostat. You can wrap it around pipe, metal rod or some heavy metal object. It will turn on a little bit above freezing temperature and turn off when the object is heated a bit.
What froze that was ruined
Any spray I use on the farm is so concentrated that it doesn't freeze at our much colder TN temperatures. For example Round Up is 50%+/- active and won't freeze until you radiator freezes.
The only materials that are affected by freezing are latex formulations- glue,latex paint and I don' t know what else. I can't think of any ag chemical that is a latex.
Move latex paint into a heated area. Solvent based finishes are immune to freezing- varnish, lacquer, stains, etc.
Dale Lenz
I'll second what John said
Dale Lenz
Used one in my 4x4x4 well house until we got rural water, worked great and didn't break the bank. Go to a well informed hardware store or a Farm and Ranch store....They should fix you up!
Safety issue here?
I would not store gasoline or any flammable solvent in a confined space with an ignition source or potential ignition source. Nor is there any reason to heat a space that is used to store organic solvents, stuff formulated in organic solvents (lacquer for example) or concentrated water solutions of organic compounds, RoundUp for example. Something as volatile as gasoline should be stored well ventilated, for example an open shed.
Latex formulations and emulsions, on the other hand, can destabilize with freezing,- glue, latex paint for example but it usually takes a few freee thaw cycles to undo them (they separate into a water layer and solids or organic liquid layer).
Terry I've done that for years. I have smaller cabinet about 2x3x6' that I lined with styrofoam panels. I put a thermostat in the top and a 100 watt light bulb in the bottom. I set is so that it keeps the cabinet above 55 degrees because I also keep epoxy in there and need it to be a little less thick when I use it. If I just had paint I'd probably set it for 45. The only problem I have with it is the bulbs burn out fairly quickly. A better choice might be some sort of heater such as the kind used to keep pipes from freezing or possibly a chicken incubator heater.
Yes and no....
John in NM
Not good to store organics with an ignition source like a lamp. Hard to say what the OP has without a detailed list. I wouldn't worry about spray cans, they simply don't leak out solvent that I've ever seen.
Recommended storage for flammable organics is a sealed cabinet rather than a ventilated space. The idea is that if there is a fire of some kind, it will quickly smother itself inside the cabinet. Explosive gases like propane are the opposite, supposed to be stored in a mesh cabinet so you can smell it if there is a leak. I can't tell you how many OSHA safety guys I've had recommend storing propane in the flammables cabinet without ever looking up the actual reg. on it!
My first thought on freezing and paint type was the same as yours, but then my second though was how rarely I see real old school enamels for sale any more - aside from rattle cans, I could see the average handyperson not having a single solvent based product in their collection. Thank the EPA for that one. It has all become about the easiest route to meeting low VOC mandates.
Try 130v bulbs
John, have you tried 130v bulbs? I got this tip a long time ago and the bulbs last longer than the 120v bulbs if your line voltage is less than 130v (most is)
130 volt bulbs are sometimes hard to find but I bough a big supply once from Amazon. I'll give you a few to try if you want.
Another thing that works even better is put the bulbs on a dimmer and turn them down a little bit. Bulbs run at a lower power like this put out less heat but last "forever."
Re: Try 130v bulbs
Also look for Rough Service bulbs. They are made for things like drop cords and have some sort of heavy duty filaments that hold up to bouncing around better than the ordinary ones. I suspect they are made for higher voltage and are not being pushed as hard as the ordinary ones also.
I JKJ has a good idea to stock up on whatever you find that works because these things are going away.
Re: Try 130v bulbs
Bill Howatt
When my father had a garage we used rough service bulbs in the inspection lights all the time since they often were dropped onto the floor. They worked very well compared to a regular bulb that often its first drop was its last.
I had a problem with bulbs burning out in my garage door opener and suspected vibration but rough service bulbs weren't any better. I got some 130V, I think they may have been labelled as "rural service" and they were much better. My line voltage wasn't really that high and the bulbs in the other opener in the double garage never gave any trouble - it was a different make.
Bill
I can't respond to warming cabinet, but but
Gary Smyth
when I used to travel a lot, (and before smart phones) I built a signal using a low temperature thermostat and a flashing strobe light, hung it in a window, and aimed it at my neighbor's house. If the temperature in the house dropped below fifty degrees, the thermostat cued the strobe and the neighbor could phone me/come over and assess any problem before things got out of hand. The closest neighbor was a little less than 1/2 mile line-of-sight and the strobe was bright and could be seen in the day and big time at night. It worked off of 120v.-- simple plug and set triggering temperature.
You might find a similar warning device for yourself between buildings helpful. The thermostat was about $50 and the strobe a bit more. Still have it and have repurposed it as an emergency signal for the same receiving home but new neighbor family.
