Lawn mower deck winterizing??
Thomas E Norton
What do you guys use for the under side of your mower deck for the winter months???
Re: Lawn mower deck winterizing??
Bruce, a MN Galoot
I change oil, sharpen the blades, treat the gas, shut the gas valve, start the engine and run the carb dry. Other than cleaning out dead grass I've never done anything with the mower deck.
yes, but.....
At your winter temperatures all chemical reactions stop, like rust for example. Other places it is good to scrape off the grass which ferments to stuff that is exceptionally corrosive to steel.
Re: yes, but.....
Bill White
Spray the deck with Pam.
Bill
Ron in Sterling, CT
I scrape it with a putty knife, hose it down, let it dry good, then slather on a ample coat of used motor oil. Have never had any corrosion problem.
Ron
Re: Lawn mower winterizing??
Fire're up on a hard surface, turn on the hose and (from the side opposite the chute) spray water under the deck until the out-flow runs clean. Other method is to power wash it (with engine off).
Let dry and spray with WD40.
Other winterizing:
1. Drain the fuel tank
2. Change the oil
3. Drain the carb bowl and leave loose, give the carb a shot of light oil spray (NOT WD40)
4. Pull the plug, give the piston/cylinder a couple shots of "misting" oil, replace the plug and crank the engine for several revs.
Ralph Lipeles
I have a vintage 1965 riding tractor with a mower deck. Replacement decks are now very hard to find so I do what I can to prolong the life of the deck. I remove it from the tractor, put it upside down on the workbench, remove the blades, scrape it clean and brush on a coat of Rustoleum.
Who's Pam? My wife may not like that!
Re: Who's Pam? My wife may not like that!
Bill White
PAN SPRAY!
Bill
Ryan
I also disconnect the negative battery lead for the winter.
Gas engines
> ...shut the gas valve, start the engine and run the carb dry. Other than
I use a big Kubota diesel mower but I assume this thread is about gasoline mowers. You don't want to run a diesel dry or it might be a lot of work to get it running again. So I just clean off most of the debris, lube the zerks, maybe change the oil, and park it in the barn. 11 years now, always starts and runs fine in the spring. (Deck rust doesn't seem to be a problem for this mower since it made of heavy welded steel plate.)
TomD
Seafoam, the gas, and run some or all through, leave it outside with wheel barrel over it, starts on the first pull. Cover muffler.
The John Deer rider, I do the seafoam, run enough through I know it is all over the moving parts and won't varnish; remove battery and store and trickle all winter; remove deck to keep it above any flooding, a few inches has ruined a bearing set; spray engine storage spray in cylinders and replace plugs hand tight; cover exhaust so mice or bugs don't work their way in.
fredhargis
The deck on my tractor comes off so the tractor can be used for snow removal in the winter. The deck gets stood on edge, and while I usually try to clean the caked grass off the underside I don't do anything else. On my lawn mower I just park it, no cleaning of the underside. I do tend to the engine stuff on it as mentioned above a few times.
