TV Antenna??
TV Antenna??
TV Antenna??
Tom
Since we don't have cable I need to get an antenna for our home. Anyone have any suggestions? Thanks!
Re: TV Antenna??
nothing specific`
But there is a web site that deals with this task. It tells where to point for each station and how many $$ you need to spend to get a good signal. An in line signal booster does indeed work. I get several stations with it I don't without. I spent about $125 for my large antenna.
Re: TV Antenna??
Re: TV Antenna??
Tom Dunlap
I live in the city limits of Minneapolis and only have an antenna
A cheap Radio Shack flat, bat wing-looking one. I don't think it cost more than 10-12 dollars. It works fine. A friend bought one similar to mine and gets all of the antenna TV stations in the area
Tom
Re: TV Antenna??
Re: TV Antenna??
Sean Troy
Best bang for the buck. I've installed a few of them and they work great.
Re: TV Antenna??
Re: TV Antenna??
Stuart Johnson
This is the one we use and it works great. It's very thin and mounted on the wall behind the tv you can't see it. We are about 25 miles from the Dallas towers.
http://www.amazon.com/AmazonBasics-Ultra-Thin-Indoor-HDTV-Antenna/dp/B00DIFIO8E/ref=sr_1_1?s=amazonbasics&ie=UTF8&qid=1446064087&sr=8-1&keywords=b00difio8e
Re: TV Antenna??
Re: TV Antenna?? *LINK*
John McGaw
Everything depends on where you are and where the transmitting towers are. Sometimes you will be boxed in by circumstances. For example, I have multiple broadcasting towers within line-of-sight from my house and I can pick up those stations with nothing more than a short piece of wire shoved into the antenna jack on a receiver. Then there are the other two stations that I'd like to pick up that are in bad locations and much weaker. To get them I really need a good external antenna and an amplifier but if I go that route the closer stations give such an overwhelmingly strong signal that the amplifier malfunctions. Luckily the stations are on the cable but when the power and cable go out, something that happens entirely too often, I'd like to have a backup to keep my elderly mother entertained. There is no winning.
You might want to look at the linked site to see if it helps with your decision.
Antenna Selector
Re: TV Antenna??
Re: TV Antenna??
Thomas E Norton
Thanks for your help!!!
