Cant hook vs Peavey
Cant hook vs Peavey
Cant hook vs Peavey
In the past I only have used a cant hook for log rolling (picture 1). Recently I had occasion to buy a broken Peavey and restored it to working order with more effort then anticipated (picture 2).
These things are expensive new and expensive used or even broken where I live. The recent logging effort was the first chance I have had to employ the peavey.
I like it for logging firewood. First, you can see in the picture its primary advantage. Its end spike provides a handy storage feature. There are hundreds of broken cant hooks in the world, a result of them laying on the ground and the fork lift rolling over the handle. In its vertical position it was easy to spot. A second advantage was the point was handy for prying saw kerfs apart as part of bucking these logs into firewood length. I didn't see significant difference between the tools for log rolling.
The peavey is harder to restore. A huge hole must be drilled to accept the end spike and overall the fitting is more fiddly than for a cant hook handle replacement. But its advantages will make it a preferred log roller for my needs.
Re: Cant hook vs Peavey
For Firewood
harvesting I use a timber jack which is a cant hook that has an opposing "T" bar to provide a fulcrum to jack the victim off the ground. With the log jacked, the kerfs don't close as you go through from the top. T bar lets it stand up as well.
Like your handle
Timber jack, peavey, cant hook
I have the timber jack, peavey, and cant hooks. Each has it's purpose. I suppose the peavey, evidently originally designed to help with floating logs, is ok for rolling logs or rounds on the ground. I generally go from ground to trailer to sawmill with the tractor and forks or dual skidding tongs on hooks on the FEL.
I find the cant hook necessary at my manual sawmill. Turning a large cant sometimes take two of us. The sharp point on a peavey used here would damage the flat surfaces. The peavy looks fragile to me, especially compared to a 5 or 6' cant hook. I also make good use of long pry bars and the forks at the mill, since I am elderly and feeble.
With a Big Enough Lever . . .
you might be able to move
the U.S. Congress?
:D
ebd
Re: With a Big Enough Lever . . .
ebd
Probably not.
I left two Peavey's in Maine in 1988
John in NM
Moved to AZ for college and figured I wouldn't have much need for them. Rehandling was easy - take them over to the Bangor Peavey Company and pay $11 each.
Jack Guzman from Maine
Expensive
I needed a peavey to maneuver the logs I buy for windsor chair building. Until I split and size them they are way too heavy for me to move around. I looked at my local hardware store,no luck. Tried tractor supply and all they had was a more modern gadjet that looked too lightweight to handle the 16" or so logs I use. So down to my favorite hardware store several towns away where they always have everything. Sure enough,they had a peavy.I even had a choice between a long or short handled version. I picked the short because it looked easier for me to use. I didn't even look at the price. I was glad to find one. When the girl rang it up and told me $129 I was shocked. I wasn't expecting it to be so much. I bought it though because I really need one.---Ouch---Jack
Re: Expensive
TomD
One used to be able to buy the hardware for not too much. Couldn't find anything like that online today.
Seems like everything is now...
John in NM
I keep hearing how we have had minimal inflation, then I look at the cost of things like tools!
Looks like Peavey Manufacturing is still around, though not much cheaper right from the source than you paid in the store. Are you anywhere near Eddington?
I did at least keep the two Snow and Nealley axes I had when I moved. Those are now made in China from what I gather.
Re: Seems like everything is now...
Nowhere near Eddington. Never heard of it.
Re: Expensive
I am always surprised by the cost of this stuff. Good 3/8" chain can be $3/ft. 28" skidding tongs were almost $100 each about 10 years ago. Most such tools are forged and last forever, though.
For anyone looking, Baileys Online (my favorite place for chainsaw and logging stuff) has cant hooks and peaveys.
http://www.baileysonline.com/Forestry-Woodcutting/Log-Handling-Tools/Cant-Hooks/Peavey-Manufacturing-Company-4-1-2-Wooden-Handle-Cant-Hook.axd
I got mine from a local place in Knoxville TN called Volunteer Wire And Rope - they carry lots of industrial and rigging supplies, rope, chain, pry bars, shovels, etc. Their prices are pretty good and they only carry top quality. I suspect there is a similar place near you but the hard thing is locating them. Lots of these places probably don't advertise on line.
http://www.volwire.com/AG%20TOOLS%20AXE.pdf
Re: Seek a Bit More
TomD
No kits there that I could
flea markets
I see cant hooks regularly at local flea markets for about $40 +/-. Other logging stuff too. Tractor supply has them but I suspect made in China and they will probably break on anything heavier than bamboo.
Re: flea markets
The tool I found at Tractor supply was designed for homeowner use and not recommended for logs of over 12" in diameter. After I bought my peavey I found a rusty one at a flea market. They wanted $60 for it.---Jack
