Rikon 34-260 Mortiser - question before buying
Don Goodwin
My local Woodcraft store has this on sale thru Thanksgiving. I have never used a hollow chisel mortiser and have a couple of questions before I purchase.
1) The handle in the model at the store (and in the pictures) is positioned way behind the motor. This seems like it will be difficult to reach in use. Can this be adjusted forward (I looked at the manual on-line and it seems to be in a fixed position)? Is this handle location awkward to use? There was a Powermatic sitting next to it at the store that seemed to have a better handle position (but was about $200 more...).
2) Is a hollow chisel mortiser (not just this one) worth buying for a hobbyist? I have always used a drill press and chisel or just a chisel.
3) I am interested in this one because of the sale price ($299) and the X-Y table. Are X-Y tables as useful as they seem to be?
Thank you in advance for your ideas.
Re: Rikon 34-260 Mortiser - question before buying
Looks
about the same as my JET [JBM-5 - see Reviews Section].
Handle is located similarly- not a problem.
Depending on what you're cutting, you may find the 1/2hp motor underpowered, but you'll learn to get around this by taking successive cuts rather than trying to power straight down in one plunge.
The supplied chisel/bits won't be much of a deal, but can be improved with a bit of sharpening of the bit and honing the inside of the chisel. You'll find yourself using a hand chisel to "clean up" the inside walls of a mortice.
Do NOT try to cut through mortices. The tear-out will be terrible. Instead, cut to about 1/8" from the other side, smooth the inside walls, then drill a 1/4" hole and use a 1/4" bearing-guided trim router bit to finish cut the outlet surface to get this:
I had to adapt a HF x/y table to my JET, so the Rikon's set-up is a real plus.
Bottom line is these are bench-top tools. It's not a $1,200 PM for 3 Bens, and it won't stand up to commercial shop use.
I've cut hundreds of joints with mine over the years. I've never needed more tool to get the job done.
William Duffield
Are X-Y Tables useful? As far as I'm concerned, an X-Y table (or cross-slide vise) is essential. The funny looking yokes that most mortisers and mortising DP attachments are equipped with, that are supposed to hold your work down, are useless. Rikon has an interesting implementation, and I assume they have "done their homework." I have not used Rikon's X-Y table, however.
Dick Coers
Is budget a major concern? I ask because I much prefer using floating tenons, and use a Domino and a multi router. Hollow chisel mortises require high grade chisels, sharpened very, very well. They tend to "stick" in very hard woods like hard maple and white oak. They get incredibly hot, and you can blue them in seconds. Then you add the noise of the screeching bit inside the chisel. Can you tell I hate hollow chisel mortises? LOL
Don't
hold back,Dick.
Tell us how you really feel. ;)
Re: Don't
William Duffield
I agree wholeheartedly with Dick, but the OP didn't ask how best to make mortises. He asked about a particular mortising machine. I've have lots of less than pleasant times with HCMs (and HCM DP attachments), so I answered at least part of his question. The only one I ever got along with was a floor mount PowerMatic, but by the time he invested in one of those, he might as well get a Domino, and save a lot of time and space and energy. I know they won't do A&C through mortises, so for those, I resort to trimming them with a chisel.
Re: Don't
disagree with either of you.
If I had the work-flow that justified the cost of a Domino, I'd be doing loose-tenon joints as well; way easier, I know, as I've done a few using the router table.
I do dust the little JET regularly just so visitors think I use it a lot. ;)
mdclor
Don, I'm located in Northern Virginia and have a Jet that you or anyone else can have for $100 including 3-4 chisels. I have moved to cutting mortises with my router and a jig. I am also a hobbyest, but find the router so much faster and don't have to pare the walls. I don't know about the Rikon, but the hold down on the Jet leaves a lot to be desired IMO.
Don Goodwin
Thank you all for your replies.
Yes, budget is a concern, but so is noise and dust. I don't build enough to justify a Domino and I am thinking that it would rival a router (or biscuit joiner) for noise and dust. My thought is that a hollow chisel mortiser would be quieter (like a drill press) and much less dusty (also like a drill press).
I live just north of Indianapolis, so northern Virginia would be a bit of a drive. Thank you for the offer, though.
Thank you for the response on the handle. It doesn't sound like I should be concerned. It also sounds like the X-Y table would be a plus. Also, thanks for the comment on not using it for thru mortises.
It now sounds like it is down to justifying the cost vs continuing to cut them by hand. I am finding that I am preferring more hand work to machine work due to the noise and dust - although I will continue to use my table saw :)
David Yoho
I guess my experience has been a little different than most of the responses. I started out like you - drilling with forstner bits at the drill press and squaring up with bench chisels. This worked but took time. Later on I got one of the early Delta bench top mortisers. However, I bought some Clico brand chisels that made all the difference in cutting. The handle on the Delta is adjustable and while the hold down is not great, it works for me. I have cut many mortises on it and it cuts accurate and smoothly. No complaints.
How about a new/old Delta?
Are you by chance interested in a Delta mortiser? I also have a tenoning jig. Both of these are new in unopened boxes; I bought them maybe 10 years ago along with other tools and stored them until I got my shop built. Now my shop is done I've decided not to use them.
I'm not really trying to sell them (they look nice on my storage shelves) but if you or someone could use either I might sell cheap or trade for something. I live in East TN so the shipping would have to be considered.
My other option (besides storing them for another 10 years) is salvaging for parts. Looks like there are some nice knobs and things there.
I am slowly moving my stored tools into the shop. About the only thing left besides these is the 8" PM jointer.
Stuart H.
Did you get the email I sent the other day?
Re: How about a new/old Delta?
Jerry Roberts
John, I have that tenoning jig. In the past week or so its really gotten a workout. It works pretty good but one has to be really accurate with your measurements to get good looking tenons.
Bernie McG
John,
What would you need to get out of the Tenon jig?
Also, what do have in mind for a trade? Wood???
Bernie, after I posted this a friend talked me into at least trying out the tenoning jig before letting it go. I'll probably do this in the next month or so and let you know if I don't want to keep it. I have more tools than space even though I am just wrapping up building a new shop. (24x62', but has machining and welding as well as wood.)
A builder friend told me once that he has seen a lot of people with a lot of tools, the difference here is it looked like I use all of mine! I don't want to let him down - if I won't make good use of it I will definitely be looking for a new home for it. All this is hobby for me.
I did find a home for the Delta mortiser this week.
Bernie McG
No problem John. Just let me know. Im trying to replace some items slowly that were stolen :(
Replace stolen items
Yikes, bummer. Hey, if you listed what you are looking for someone might have extra stuff to share. I know I have a few extra woodturning things I give away at times.
Where are you in the country?
Re: Replace stolen items
Bernie McG
I am in N.E. Ohio
When you decide either way just let me know.
