shaper fence for router table
Doug
What are thoughts of using Delta HD fence when making a router table??
Re: shaper fence for router table
William Duffield
It depends on whether you already have one or can obtain one inexpensively, and can use it to simplify construction details. Since you have not provided a model number, we may be imaging a different fence than you are considering. Some disadvantages: It's heavy, and over time will cause a lot of wear and tear on the table top. You will also need to design the table to support its weight and to just stabilize it and bolt it down. It takes up a lot of real estate, in particular behind the blade, requiring a larger table, and especially more intrusion into the room. You may have some challenges designing and implementing dust collection for it. None of these difficulties is insurmountable, but it helps to be an engineer, or at least think like one. On the positive side, if you are planning on using the router table for jointing the edges of boards, the split fence mechanism should make that a lot easier than the arrangements I've seen on most router table fences. Personally I prefer to use a jointer for jointing, so that feature would mean nothing to me.
It would be pretty heavy in my opinion. I lucked out and ran into a new in the box Bench Dog pro fence at a moving auction. Think I paid $15 or $20 for it, I really like the fence, easy to adjust, includes shims for relocating the left fence when cutting molding. It clamps very well etc.
