hydraulic/bottle jack question
Jerry Gibbs
I have a bottle jack that will not retract fully. It will extend. There is what looks like a fill hole half way up the side and a valve at the bottom. With the jack on its side and the cylinder almost in, I filled the jack with fluid, which looked low. This did not work. I also filled the jack with the cylinder fully extended and it looks like I over-filled it. I purged most of the fluid when I fully unscrewed the valve. Any help is appreciated. Jerry
