Shepherds Hook project
Rick Snyder
Hello,
I've been asked to make a shepherds hook for a class play. Steam bending is not an option at this time.
I will be using maple (?) Any suggestions would be appreciated.
Thanks, Rick
Rick Snyder
Hello,
Thanks, Rick
Re: Shepherds Hook project
Raised sheep for 40 years and never saw one. That said if I was tasked with this job I would find a limber sapling, cut it and bend to shape, let dry. Maybe peel the bark somewhere in the process. I recently spent an afternoon clearing shooting lanes where I will hunt deer. I didn't pay much attention to what I was clearing but some saplings snapped when I tried to break them over and others bend into a small radius before cracking but never breaking. Use the latter variety.
Yonak
How about cutting it out of plywood or MDF ? It will be painted, right ?
+1 for plywood
Dick Coers
Laminate a couple of pieces if you want it over 3/4" thick.
Re: Shepherds Hook project *LINK*
Mark Hennebury
You can buy them online
http://www.amazon.com/Handcrafted-Depictions-Frequently-Significant-Shepherding/dp/B00A4V1AWW
The llama/alpaca people often use them since camilids are notoriously unapproachable.
Some years ago WoodCentralian JL made some for me (with steam bending) and I keep one right by the barn. Our llama expert/mentor uses it occasionally. I usually resort to bribing them with food instead.
walta
If you do not have a year for green wood to dry.
I would saw long strips about 1/8 inch thick glue them together clamped to a form. Once dry round the corners on a router table.
Stage props are often very different from the real thing. Try filling plastic electrical conduit with sand capping the ends. Dip the end in boiling water it should bend nicely to a form. Once cool cut off the caps and drain the sand, paint as needed.
Walta
Rick Snyder
Thanks for ALL the great advice!
John Foster
Several years ago I made a bishop's crozier to use in a church play. I made thin maple sprips (1/16") and glue laminated them together in a form made from scrap lumber. It turned out well.
A year?
I will place a wager that a 1" bark-free sapling will dry sufficiently to hold its shape in 2 weeks in an indoor heated environment, or 2 hours if the crooked end is stuck in the oven.
Re: A year?
Hank Knight
We used to make slingshots from green dogwood when I was a kid. We'd cut a 3-forked stem, tie the two side branches together, shape them into the desired curve and bake the branch in the oven for an hour or two. When it cooled down we'd cut the center stem away, add rubber sling straps, a leather pouch and we were set. I still have my favorite I made 60 years ago, and the shape is still perfect. Hasn't moved one whit in all that time.
Laminate it
You could make a form, rip your laminates and have the whole thing glued up in an hour with one band clamp. You might want to make the curved part of the hook by itself and then scarf a straight piece on one end. Experiment with the thickness of your laminates to get something that will bend with moderate hand pressure to your intended radius. If theyre too thick, you'd need to hot-pipe bend them prior to glue up, otherwise you'll never pull them together.
