What is this for?
What is this for?
What is this for?
Terry Alexander
Here is a pick of the table of my Craftsman 15 1/2" drill press. I kind of inherited it. Had been left in a shop that had a leak. Anyway...I have it all shiny and restored now. But for the life of me, I can't think of what is supposed to be mounted on the "kind of" back side if the drill press table. Here is the pic.
Appreciate y'alls assistance.
Terry Alexander in West Texas
Re: What is this for?
I assume it is for a handle that would screw in and tighten the table to the riser tube.
T
John McGaw
Does the unseen part of the table have a locking mechanism to fix it to the upright? If so then it isn't likely to be for locking. Is the hole threaded? If so, might the hole be for mounting some sort of tilting table since I see that your main table is fixed?
andrew nistock
if I remember correctly this may be where you attach part of the mechanism for a rack and pinion lift system. Not sure but I cannot find the manual for mine. bought mine 35 short years ago.
Andy
Roy Girolami
I had a similar drill press years ago. Sears sold an auxiliary table that could be tilted. It mounted on that boss with a bolt through the hole.
Roy
Add on lift mechanism maybe?
Never knew this until replies
Gary Smyth
Tilt table as per John and Roy. Not the bicycle chain table lift connector as I thought. I have two of this drill press and never knew about tilt option.
Re: Never knew this until replies
TomD
Interesting option, never seen such a thing.
Exactly
Rod Peterson—Ormond Beach, FL
I bought one in the '70s for my circa 1972 Craftsman DP. It wasn't nearly as useful as I'd hoped. In fact, I'd be hard pressed to recall ever using it.
I also had the chain lift for my DP. While helpful, it had a design flaw that made it a little irritating to use. Can't remember details, now, as I've been well and truly rid of it (the DP) for nearly a decade.
Rod
Joseph Mulherin
Try looking into Rockwell tools. They have the lifetime supply on their batteries.
I know what I would use it for
Ralph Lipeles
Looks like a good place to screw in a bolt so that you could attach a flex cable going up to a top mounted pulley and then down to a counterweight. A counterweight makes it significantly easier to raise the table.
Jerry Nicholson
I have had a Craftsman DP with this tilting table "feature" since some time in the late 60's or early 70's. I bought the tilt table but I don't think I ever used it. I think maybe I threw it away sometime in the last 15 years.
My DP still uses a repurposed sump pump motor.
Jerry
