Re: Rockler shutters
Michael Wilkins
I made a set of fixed shutters for the front of my home earlier this year (actually 4 sets) using the Rockler jig and bushing. I had the jig for a couple of years before I decided to get off my butt and get it done.
Instructions are fairly straightforward and easy to set up. I used Cypress lumber, hoping to get longer life out of them versus the pine shutters that were on my house since it was built (1985). They were made with the intention of painting, like the originals were. So with the combination of a rot-resistant timber and paint, they should last a long time.
During the construction, I kind of wish I had used some type of hardwood, as plunge routing the Cypress leaves a rough finish around the holes that had to be sanded off. And the bit sometimes forced wood chips into the mortise that had to be individually cleaned out with an awl.
Rockler gives you the option of purchasing their slat material, or you can make your own. This means cutting many 1/4" strips of the proper width, and making many passes on the router table to round over each edge. Lots of work for me but I had the material on hand and just put in the work.
Rockler sells both a jig for fixed and moveable slats; which you choose is your choice. They offer some nice jig set-ups for many operations; and at a reasonable cost.
Good luck and watch those fingers.
