FlowerFall Cabinet
FlowerFall Cabinet
FlowerFall Cabinet
McKay
I just finished this cabinet today that I call FlowerFall. The flowers are Holly and are sand shaded.
The box sides are walnut with the top and bottom cherry. The top of the box is Walnut in the shape of an "O- tori" gate.
The legs are cherry with the back left leg continuing the flowers down to the ground. I use a green burn in lacquer stick for the vine of the flowers
The shelves are paudouk. (hardest wood to scroll that I have ever worked with. I went through 8 blades before I had one scroll done)
Here is the last picture with the cabinet open for display.
I will be out of the shop for the next 18 months so I decided to get this done. It is for my own home.
The dovetails are hand done as are the small re-woven pull handles. To balance the weight of the two halves, I put slides on the bottom of the back half. When the cabinet is opened, you slide the cabinet to the left which puts the two halves weight over the center of the legs.
Hope you enjoy.
Re: FlowerFall Cabinet
Mark Hennebury
Looks to be a beautiful cabinet! i would like to see some better photos to see more detail.
Mark Hennebury
Unsolicited comment
Gary Smyth
I'm hesitant to reply because it is such a handsome cabinet. Congratulations. The falling flower theme is terrific -- especially the wrap around petals. One thought though. To me the rope beckets seem to be a bit rustic. They seem to me to be moderately rough when compared to the cabinet. I understand that it must have been a triumph to splice the rope rings but in your upcoming travels you might watch for an Asian seawall style forged iron ring or a woven rope becket which to my eye might make your work even handsomer. The existing rings could also be waxed/varnished to cut down the wild threads.
Your cabinet is a beauty of work.
What is the finish?
It did nicely on the dark wood and didn't color the holly.
Multiple coats of shelac
handles
McKay
I lived in asia for two years and agree completely with your comment on the handles. However, I am able to make the rope handle as I did on the 8 sea chests that I did but because I am totally inept with metal I went with the what I knew. Thanks for your comment.
Very beautiful work. The proportions, overall design and inlays are very pleasing. I must join the others about the rope loops. They are a disconnect with the design. I would suggest metal loops. Aside from that, it's a winner!
T
check Whitechapel
they carry a selection of wrought metal hardware.
Mike Van Pelt
WOW!!!!!Beautiful work! "I am not worthy oh Master" What a wonderful family heirloom you have created!
How many children do you have to fight over this magnificient piece! LOL!!!
thanks for sharing,
Mike fro CU
Sgian Dubh
Closed, I rather like it, and the sand shaded marquetry flowers add visual interest. On the other hand, the cabinet is visually ungainly when opened, with its small footprint, a pair of large overhanging wings left and right, and dead space at the top front of the base. The piano hinge, although functional, is unattractive - some high quality hinges of a different type might have served better aesthetically, e.g., brass butts, barrel hinges, etc.
The clam-shell form of the cabinet means the display items are sat on moving parts which might disturb them as the cabinet is opened and closed. If they are really display items, why do you need to open the cabinet to show them off? Shouldn't you be able to see them through, for example, a glazed door or doors, so you only need to open the doors to rearrange the items, clean the display them, or remove or add alternative pieces? Slainte.
