Using Plunge bits for Faux raised panel look in M
Mark
Has anyone had any luck with this approach. I would like to make some simple, inexpensive,painted replacement kitchen cupboard doors for the cottage. The thought of setting up the rail and stile set and raised panel bit is not appealing for this project .
Lee valley has a 3/4" plunge bit..thought it might work?
Re: Using Plunge bits for Faux raised panel look in M
Skip the router
All you need is a scratch cutter for this and do it by hand. It's an old tried and true way to do faux beads. Here is a link to a Fine Woodworking article for making your own scratch stock.
T
http://www.finewoodworking.com/item/57331/how-to-make-a-scratch-stock-for-beading
Dick Coers
So you aw thinking about running the bottom of the bit on the face of the panel? You'll have a lot of circular lines to clean up if that's the direction you are going. I would cut out most of the stock, then set up a vertical router bit cut to clean up the saw marks.
Is that suppose to be MDF?
Keith Newton
You would do well to call around in your area to find a door shop, and just have them make some to match. The price is really not that bad in my area.
Re: Is that suppose to be MDF?
Mark
Yes MDF was what I was planning on using.
Idea was to set up a rectangular jig that would surround the door panel and with a plunge router and bit run the router around the jig , routing out the grove and leaving a 2.5 inch rail and stile effect around the door panel.
John in NM
I don't see any reason it shouldn't work from a technical point of view. It's always going to look like what it is though.
One thing you could try is routing more than one profile using your jig and some spacers. Start with the outer most groove that imitates the rail and stile edge, then step in 3/4" or so by adding spacer blocks to your jig and imitate the raised panel cut with a different bit.
This is just off the cuff of course, no idea which bits you'd need to use or what spacing would work.
mdclor
Mark, it might not be the look you are after, but you could just apply a rectangle of molding to the face of the MDF.
