Building a garage/shop at my parents house?
Charles Jackson III
I am wondering is it a wise move to build a garage/woodworking shop at my parents? I cant afford a place of my own right now because I only make $10.60 and hour but I still wont to start back woodworking again!
Re: Building a garage/shop at my parents house?
Dick Coers
Sounds good to me if they don't mind. Why not put a loft apartment in it? Kind of like moving out that way, they get a guest house when you do move out.
Charles Jackson III
Maybe a good idea!
Jerry Gibbs
I have a second shop at my daughter's, located about 5 miles from me. It does get used and my son in law is interested in woodworking. You didn't say how far you live from your parents. Build it as big as finances and zoning laws allow. Run as much electricity to the shop as you can, at least 100 amps. Jerry
Joseph Mulherin
Charles, first off my question is:how much construction experience do you have to begin such a project?
1. need construction plans approved by county or city; need funds to cover the construction+ 20% more to cover unforseen expenses; construction knowledge of how to do the concrete forms and maybe floor;
after floor is done, prefab the walls upper and lower if needed, and get a good neighbor or relative to assist. and a whole lot of luck
Charles Jackson
I live with parents.
Charles Jackson
I took up carpentry and cabinetmaking in trade school
RK near Boston
Build away, why not, as long as you get along with your parents it is a win win type situation.
Joseph Mulherin
If the new addition is going to be on their house....are they going to cover the expenses of an addition?
An additional thought: look into putting dust collection ports in floor and maybe overhead for flex hoses to go to machinery with blast gates; And electrical ports in floor so you do not have cords to step on ;
good LED lighting all around the shop; white or tan walls;plywood all around walls so you can screw anywhere you need to put up any tool racks, wood racks, there are some very good videos on YouTube about almost any tool or cabinets, benches you might peruse to make your plans.
Work you ideas out on paper first, then move things around if they do not fit like you think they should.
It is better to get your thoughts straight on paper(cheaper too) before anything is begun.
Just me rambling and trying to help.....Joe
Charles Jackson
It's going to be a detach garage
If you are going to build it on property that is not yours but are going to pay for it yourself, you might check with a lawyer concerning possible future legal issues. It would be sad to invest tens of thousands of dollars and all the effort now only to lose every bit of it later.
I designed and built my shop myself and it is a major undertaking. Beyond things like building permits you have to consider the design - will it be conventional studs on a concrete slab? Pole barn style? Metal building? After planning there is the electrical to run, grade and forms and rebar to prepare, concrete to pour and surface, walls, trusses, roof, doors, windows, siding, wiring, insulation, paneling, etc. When planning the placement and grade, don't forget the unbreakable rule: keep the water away from the building!
If you have no construction experience there are lots of books available with ideas. I have several that concern farm buildings I got ideas from. (My building is 24x62, concrete floor, post and beam (6x6" posts), 9' ceilings, metal roof, 1/2" ply paneling inside.) Fortunately I have backhoe and bobcat and carpentry tools and was able to do everything myself except for surfacing the concrete and setting the roof trusses with a crane. I did my own forming and rebar, wiring, DC, and HVAC as well.
You can save a LOT of money building it yourself but it may take a year or so and it is a huge amount of work. The more you have to pay specialists (concrete, roofing contractor, electrician, etc) the more it will cost. If you don't live in the far frozen north it might be cheaper to hire someone to put up a metal building on a concrete slab.
It is helpful to get some idea of how much it would cost to have someone else build the whole thing. This might give you an appreciation of the amount of effort and time involved.
Whether you do it yourself or hire someone to do it, you need to have everything planned out ahead of time or risk unpleasant surprises. I probably made 50 pages of drawings of everything from window sills to wiring diagrams before I put up the first posts. I drew scale floor plans and moved little paper cutouts around to represent machines and workbenches until I narrowed down the plan. The building went up without a hitch and is a fantastic shop now, if I say so myself! However, I had experience building a number of other buildings over the years and plenty of tools. If I didn't, I would try to find someone who did who could work with me.
About to build another one this fall - a 30x60 horse barn/bees/equipment building. Good clean fun!
Joseph Mulherin
Still my ideas presented to you for the dust and electrical outlets should be looked into.
Do a layout of the equipment on paper, move them around if they don't seem readily good for
good work smoothness(moving from one piece to another, i.e. chopsaw to tablesaw or lathe, planer, drll press) I mean doing one thing then moving to another tool for another thing to do on the wood....planning.
garage door: overhead or sliding? motorized? plan on putting retractable wheels on all pieces of equipments for moving in the future; overhead ibeam for moving heavy wood or equipments?
electric outlets every seven feet on walls, multiple outlet mounted on front of bench.....just thinking
of possibilities for you.
John in NM
In a word, no, probably it is not wise. Generally if you can't afford to rent space, you definitely can't afford to build it either.
If you had to get a builder to do it all, you're probably looking at between $30 to $50 per sq foot, and those figures tend to assume a 2 car structure (price per sq foot tends to be lower for larger structures). Around here, a truss costs $100 whether it's a 15 foot span or 30 foot span.
Now if you have the time and skills, you can do it a lot cheaper yourself, but it does require a great deal of both. Out where I live you can do everything yourself except gas piping. Some communities do not issue permits to owner/builders however.
How much space is available and are there any neighborhood restrictions? You might be able to get a shipping container instead and use that. If you have room, you can do two with a covered space in between. Quick and easy. Kinda ugly, but quick and easy, and relatively cheap too.
Joseph Mulherin
John, we think alike.....plan ahead for everything. I was a Foreman on many construction jobs. I made schematics for the guys of lots of sections of the jobs, bought and had all the pipe and fittings already
for them.....when came time to do the job gave them the schematics and told them to go at it.
No labor problems ever.....just good planning from the start. The jobs were finished in my mind before they were started.
don stephan
Will the cost of the building be recoverable if/when the property is sold? If not you are taking more risk.
Charles Jackson III
Been thinking about that, the value of the houses in my neighborhood are dropping. Another option is building a small shed to store my woodworking machinery until I can afford a place of my own.
trusses and containers
Yikes. The trusses I bought for my shop a few years ago and those I priced recently for my barn (both 2x4 with 2x6 top chords) were less than half that!
Around here we can buy either shipping containers or a trailer with the wheels cut off. I bought an 8x8x40 aluminum shipping container that I use for hay storage after adding vents. Earlier, for less than that I bought an 8x9x45 trailer for storage, again all aluminum except for the steel floor support. Both were around $1500 plus about $100 to deliver, pretty cheap for an instant building.
I was advised to buy aluminum since the steel roofs will rust out unless you keep the leaves cleaned off.
You're probably closer to the factory
John in NM
Two hours down to Roswell, they deliver. Probably get trusses cheaper in Albuquerque, and these days they might deliver. Last time I bought any, ABQ vendors had enough business to not worry about customers out in the sticks.
RK near Boston
Just build a 12x16 shed and do handtools, do not overthink it. You probably do not want to spend lot of money on a machinery either. Get a handsaw, plane, some chisels and get going:)
Charles, Lots to think about here. If you build a permanent building on someone else's land, it becomes their building. It might or might not increase the value of their property. Another approach would be to buy a building like a garden shed and have it hauled in. Locally I think they can deliver a 256 square foot building without getting a building permit and getting tangled up in a lot of regulations. Check with somebody selling the buildings in your area. They can haul it in and set it up on a few piers laid on the ground and be done with it for a few thousand bucks. My son had one put in place for less than $4,000. You could have it in place in a week or two and wire it and be wood working soon after. You would need insulation and heat, but you would need that in a building you built as well. (have a door in the end, so you can set up a table saw and rip something long by opening the door.) You can build a lot of stuff in a 12 by 20 shop.
An advantage is that if you move or your parents sell the house, your building could be moved to another location, or sold with the house.
Joseph Mulherin
I agree with Barry.
I looked into floor ducting of my dust collection system, but discarded the idea of having my equipment tied to one spot. Family, friends and I built my 30X30" shop (from my hand drawn plans) to accommodate moving my equipment as needed. I installed mobile bases on my 8" joiner, 20" planer, Delta Unisaw, MM16 band saw, Router table, etc. and went overhead with my dust collection piping, placing wall drops with gates at various locations on the walls. I use flex tubing to hook up to the equipment, everything seems to work quite well for me. This does give me and my son's the ability to move the equipment out of the way and work on a vehicle when needed. It also allowed me to join and plane 16' + lumber when needed and to clear an area for large project assembly.
I agree completely about installing Many outlets. I installed the largest 100 amp entrance box I could find. I installed 120V outlets on every other wall stud (on 16" centers) and a few extra. I also installed 3 banks of outlets on the ceiling for florescent lighting, and a half dozen incandescent porcelain light fixtures for halogen bulbs. Each bank and the fixtures are on separate light switches. I installed several 240V fixtures on the walls and made up heavy duty extension cords for my equipment.
A couple of things I did I would recommend is that I used 2X6 studs for the walls, this allows for extra insulation and also lets me mount anything I want on the walls without worry. I also laid 3 or four courses of blocks on the foundation so that I have 10' plus ceiling height. I ordered custom trusses for the roof that allowed for a 10' wide by 8' high room upstairs (the cost increase for this was minimal compared to standard trusses). As I was designing the shop myself, I found good quality thermopane windows at a very low cost by buying odd size (to the supplier surplus windows) and designed around them. Having the room upstairs (I have a drop down heavy duty attic type ladder for egress), I was able to install my downdraft furnace with central air upstairs. The furnace is NG, with a sealed combustion chamber which takes in combustion air from outside and exhaust out in 2" pvc pipe. This eliminates any worry about solvent fumes or dust entering the chamber.
The previous posts also mentioned that if you proceed with building your shop you need to talk to the officials regarding permits and requirements for location, size, construction standards, foundation requirements etc.. This is essential before doing ANY planning.
Me too.
John E in SC
I second the portable building idea. It's what I started woodworking in. Would occasionally have to assemble bigger pieces outside, but you can do a lot of work in a 12x20 building, and it's pretty inexpensive to get started. Then if / when you get your own place, you can either take it with you, or if you ever decide on a larger space, who can't use an extra storage building?
One more thought.....
You might be able to set the building up on some sort of affordable payment plan and pay over time. Might help you get moving.
Re: You're probably closer to the factory
Ah, that might explain it, even though the truss lumber is shipped in from the other end of the country. There are several local suppliers with truss shops. The one I use doesn't charge extra for delivery, at least for my location, about 30 miles.
The delivery charge is certainly built into the price, but about $50 for a 24' 3:12 with 2x6 top cord delivered sounds pretty good after hearing about your trusses.
This is a pretty good area for building and living. (East TN) The costs of housing, land, and living in general are low - I paid less for a 27 acre farm with a sound timberframe house than many pay for a house and yard in an area suburb or in town, and those are FAR less than many areas of the country. Things like gasoline at the pump are usually even lower that what the news reports as the lowest in the country. Knoxville is kind of a central hub for the eastern US where major N/S and E/W interstates cross (I-75 and I-40) and that must lower transportation costs. There is a major gasoline hub also with a huge number of giant gasoline storage tanks. The central location also puts us within reasonable driving distance of most of the east from Florida, the east coast beaches, and the north from Chicago to New York. The Smoky Mountains and zillions of acres of woods, lakes and rivers for hunting, fishing, and watersports are in our back yard. (And great turning and furniture hardwood grows on trees around here!)
So far I've talked two people into upping and moving here just by describing the area. Maybe some regional economic agency should pay me a bunch of money. :-)
