A55 Smoothing Plane
Demilune Tale build- Design
First, let me thank those that have offered advice on building this kind of table. I saw my woodworking hero Will Neptune demonstrate clever techniques for building this kind of table but at the time I thought I would never build one and didn't capture the techniques demonstrated. :(
What: A Demilune is a table with a half moon (circle) top. They usually have spindly tapered or turned legs. They rarely have a drawer (for good reason).
Why: Daughter needs a table at the entry of their house. The table needs to go between the entry door and an adjacent door with 36" of space between. A small demilune would be ideal here as its curved top would offer less obstruction than a rectangular "Hall" type table.
Design: By placing half demilunes of cardboard in the space it was decided that a top 26" across was ideal. To up the challenge I decided to add a drawer. The drawer will be contrasting veneer with cock beading. The main design challenge is engineering the apron and drawer support and deciding on the drawer size and location details.
I have found that if I draw a scaled drawing of a rectangular piece of furniture that if it looks right on paper it will look right when built. I have similarly found that this approach doesn't work for curved stuff.
At the College of Redwoods I found the students doing mock-ups of their proposed pieces. I thought it might be a good idea to mock up the leg and drawer location and reveal around the drawer. I used a bent piece of Masonite, added some "legs" and drew in the drawer with various reveals until it looked right, about 3/4" top and bottom and 13/16" sides. (don't confuse the drawer in the bench that the mock-up is sitting on for the Demilune drawer which is drawn on the Masonite. )
Caution: A bent piece of anything does not bend into a semicircle or any other simple geometric shape. The resulting shape is a complex mathematical function derived from the engineering field of Statics. However, part of the bent Masonite is close to a half circle and I used this part for the mock-up.
The next step is to engineer the curved apron, which will be veneered. I intend to use the Period technique of "brick-work", to be described in a later post.
Re: Demilune Tale build- Design
Re: Demilune drawer
Gary Smyth
Of course you have your own design ideas, but perhaps you might wish to consider a sliding dovetail for the front drawer side connection? The one I have has a particularly thick drawer side to accommodate a dado for the drawer slides. The rear of the drawer has through dovetails. Mine is machine made from the 1930's. The drawer bottom is a heavy 5/16 thick I'm supposing to better support lots of use and the storing of numerous keys. (Or maybe it's all they had on hand at the time.) Best wishes on your project.
Jesse Cloud
Looks like a really interesting project, looking forward to seeing the build!
One caution about an entry table. I have a demilune entry table with a nice sunburst veneer on top. But I cringe every time someone comes in an tosses keys, packages, purses, etc on the veneered top. If I were to do it over, I would seriously consider a solid top with an easily repairable finish.
John in NM
How about some glass? A little cheesy looking, but sure beats fixing key dents!
I bought a lot of dual pane window glass from Dwight's when they were down on Lomas or some such street. Looks like they've moved up to Alameda west of I-25 now. They did pretty much everything from windows to beveled mirrors, etc.
the top
The table is intended for just the use you describe. The top will be solid walnut with a durable finish.
