Need some help here. The fella I made this cutting board used it once, rinsed it clean and then noticed this. I assume it's some sort of mold. But it's under the finish which is Velvet Oil. Any tips as to what is going on and what can be done to prevent/fix it? Thanks, Paul
1. I would never make a cutting board out of a porous wood like oak.
2. If it is mold Chlorox will bleach it colorless. If it is mineral stain (iron for example) Chlorox will not affect it or make it worse.
3. I have no idea what "Velvet Oil" is. Typically oak is toxic to mold so I am doubtful mold is growing on the oak. It could be growing on the oil or food lodged in the oak pores.
4. Ignore the problem. If this board is a "user" it is going to look a lot worse than what it is now after months of use.
Oak has a lot of tannins which react with chemicals naturally occurring in water, they might be causing the black spots.
I agree with Bill on just using it. Chefs scrape their boards often with the dull edge of a cleaver to clean them up, probably a good idea for home cooks, too.
And its a shame thats happening, the banding is really cool. Maybe you could scrape it clean, put a film finish such as varnish on it and call it a cheese board!
I'm familiar with Velvet Oil. It looks like possibly the oak reacted with perhaps iron in the water or something. If that's the problem, you're not likely going to fix it by washing with something like bleach.
the staining I have experienced when I left behind particles of iron/steel...like from steel wool or grinding dust from a nearby grinder....or the like.
When water hits it the reaction is nearly instantaneous.
What was your finishing schedule, and is this product a version of Danish oil (equal parts mineral spirits, linseed oil, and varnish)? Also looks to me like black iron stain on oak.
Great that the stains have been explained, but how to avoid repeat on this piece in the future? Not sure if the velvit oil didn't block water when the piece was washed, when the piece was used the velvit oil finish was compromised by knife cuts or similar, or . . .?
Perhaps removing 1/32" of surface all around would remove all remnants of the steel wool, but in theory a power or hand planer could leave new tiny bits of iron/steel.
Oxalic acid might counteract the staining to some extent, but may not completely remove it, depending on how deeply the stain has penetrated into the open pores.
In the future, for oak, instead of steel wool, use Norton or 3M Synthetic Steel Wool ScotchBrite pads or brass wool.
I agree with the others. You are probably dealing with steel shards from the steel wool. Oxalic acid may reduce or eliminate the staining but maybe not.
As said, a deep pored wood like oak is a poor choice for a cutting board. Food particles can become embedded in the pores. It's best to use woods that have little or no pores. Maple, birch, and cherry are the traditional choices.
Another point. cutting boards that are intended for use to cut meats and vegetables are most often left unfinished. Any film finish is damaged by cutting and chopping leaving places where juices can enter the wood. Here is a treatment that many use and is used of commercially made boards.
An excellent treatment for wooden food preparation surfaces like cutting boards and butcher blocks is a mixture of mineral oil and either paraffin or beeswax. This is what is used on many commercial wood surfaces. It will last longer and be more protective than just mineral oil. Mineral oil can be found in most supermarkets in the pharmacy section or in a true pharmacy. Paraffin is found in the canning section of the store or in a hardware store.
Heat the oil in a double boiler and shave in some wax. The exact proportions are not critical--a 5-6 parts of oil to one part of wax will work fine. Stir the mixture until all the wax is liquefied. Apply the mixture heavily and let it set 10-12 hours or overnight. Next day do it again and continue until the wood will no longer absorb the finish. Let it set for 10-12 hours and then lightly scrape off any excess. Then buff it with a rag.
Reapply whenever the wood begins to look dry.
Never put a wood board in the dishwasher and don't soak it in dishwater for long periods.
